Stripped ALLEN bolt.. ANY IDEAS?
Old 08-25-2011, 01:01 PM
i pooped a squirrel
Gen_Crunchytoes's Avatar
Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes Gen_Crunchytoes
Default Re: Stripped ALLEN bolt.. ANY IDEAS?
I was gonna say its a bad idea to use an extractor when you first made the thread. I gewfd lol
Gen_Crunchytoes is offline
Old 08-25-2011, 01:18 PM
kadafiz's Avatar
kadafiz has disabled reputation
NEW PIC OF EASY OUT SNAPPED ALL THE WAY IN lol.. And yes still stumped!
kadafiz is offline
Old 08-25-2011, 01:19 PM
kadafiz's Avatar
Sounds good and i might even give it a shot.. but the thing is torqued on tight.. so I don't know if it will work..
Originally Posted by MICK LVN
My idea if you are still stumped: (hope not)
Dont know what type of angle you have on it, but maybe notch the outside edge like this "v" and outside edge, place a flat head or punch on the "v" you made and try to tap it with a hammer in the direction you are trying to turn it. sounds wierd, but I have done it before. But it is hard to see the room you have to work with around that particular piece.
kadafiz is offline
MARK IT ZERO
ufctapout's Avatar
biwp
ufctapout is offline
Old 08-25-2011, 01:21 PM
Its Lightish Red
JStab's Avatar
JStab JStab JStab JStab JStab JStab JStab JStab JStab JStab JStab
Put a bolt in that hole, weld it, remove bolt.
JStab is offline
Old 08-25-2011, 01:25 PM
MICK LVN's Avatar
MICK LVN MICK LVN MICK LVN MICK LVN MICK LVN MICK LVN MICK LVN MICK LVN MICK LVN MICK LVN MICK LVN
Never know, the "shocker" effect we use to call it at the shop works sometimes.
MICK LVN is offline
MICK LVN's Avatar
If you can so this, this will be your BEST bet at this point. Never fails if you get a good weld on it
MICK LVN is offline
Old 08-25-2011, 01:26 PM
kadafiz's Avatar
Sounds good.. What welding equip would fit best for this?
kadafiz is offline
Old 08-25-2011, 01:28 PM
kadafiz's Avatar
TY for the help guys.. Welding seems like the way to get these bitches off.. And will I have to replace the rocker shalf since the easy out seems to be stuck in it and if I see no damage once i pull it out is it safe to put it back in?
kadafiz is offline
Old 08-25-2011, 01:30 PM
i pooped a squirrel
I can't say since I don't know much about welding yet, but I will say make sure you have a good welder tac the bolt on. I had to try a similar idea (mick actually gave it to me) a while back when I broke a banjo bolt off inside a brake caliper, needless to say my inexperience with a welder warranted replacing of the caliper
And if your unsure of the rocker arm, have a good shop or machinist look it over
Quick Reply: Stripped ALLEN bolt.. ANY IDEAS?
