starter problem
Old Apr 6, 2009 | 08:22 PM
ridinboost757's Avatar
I <3 757
ridinboost757 is a name known to allridinboost757 is a name known to allridinboost757 is a name known to allridinboost757 is a name known to allridinboost757 is a name known to allridinboost757 is a name known to all
Default starter problem
Just finished my ls swap and when I go to turn the key the starter only clicks once then nothing. Switched out the starters and still the same single click. Any ideas?
Old Apr 7, 2009 | 05:29 AM
Scottyk6's Avatar
Full-time New Guy
Scottyk6 has much to be proud ofScottyk6 has much to be proud ofScottyk6 has much to be proud ofScottyk6 has much to be proud ofScottyk6 has much to be proud ofScottyk6 has much to be proud ofScottyk6 has much to be proud ofScottyk6 has much to be proud ofScottyk6 has much to be proud ofScottyk6 has much to be proud ofScottyk6 has much to be proud of
Default Re: starter problem
Weak/old battery?
Old Apr 7, 2009 | 09:11 AM
I <3 757
Well we have a booster box connected to it while trying to startup, lights in the car don't dim as if the battery is dead/low power.
Old Apr 7, 2009 | 10:17 AM
It sounds like the solenoid is switching, but that there isn't enough power to turn the starter (or there isn't any power at all) so you should check at and around the starter, starter solenoid. Many cars use a small relay to switch the (much larger) starter solenoid on, so that may be the click you're hearing.
I'm guessing you either have a corroded connection (probably a corroded ground connection) or a loose power or ground connection.
If the lights are not dimming, that probably means that power isn't reaching where it should be. If there isn't a big current load then the lights won't dim, if that makes any sense. So if the starter isn't completely connected, the lights aren't going to dim because the starter isn't drawing current.
Old Apr 7, 2009 | 11:47 AM
thermal's Avatar
TurboPipingSystems
yes, check the ground wires.... also, manually crank over the motor from the pulley. Make sure that the motor is not seized.
Old Apr 7, 2009 | 11:49 AM
If it was seized the lights should dim really bad, the starter will draw a shitload of current if the starter motor is stalled like that.
pasty
Oct 24, 2008 08:44 AM
Stillpushin
May 24, 2007 05:05 AM
