SR20det reading stoich at all times and bogging
Old Jun 16, 2008 | 09:12 AM
Default Re: SR20det reading stoich at all times and bogging
Works for troubleshooting maybe. They're worthless as an air/fuel ratio gauge though.
Old Jun 16, 2008 | 12:05 PM
WhiteEg6's Avatar
Straight Goonin'
WhiteEg6 WhiteEg6 WhiteEg6 WhiteEg6 WhiteEg6 WhiteEg6 WhiteEg6 WhiteEg6 WhiteEg6 WhiteEg6 WhiteEg6
I have an extra o2 you can have man, i have a wideband on my SR so i dont use this one.
WhiteEg6's Avatar
Straight Goonin'
hold on, i'm almost sure i have it still. just PM me if you still need one and i will let ya know if i still have this thing.
Old Jun 16, 2008 | 07:10 PM
LSX240's Avatar
10th planet student
LSX240 has disabled reputation
im not sure if i need it, but if i do i will let you know fo sho, thank you very much
Old Jun 16, 2008 | 07:11 PM
LSX240's Avatar
10th planet student
oh yah , i forgot to say, i ran the codes on my ecu and it came up as "55" which means there is nothing wrong. im confused. but the car runs fine now which is weird because my useless A/F gauge is not reading like it used to
Old Jun 17, 2008 | 07:04 AM
Beachin_240's Avatar
Snoochie boochies
Beachin_240 has a reputation beyond reputeBeachin_240 has a reputation beyond reputeBeachin_240 has a reputation beyond reputeBeachin_240 has a reputation beyond reputeBeachin_240 has a reputation beyond reputeBeachin_240 has a reputation beyond reputeBeachin_240 has a reputation beyond reputeBeachin_240 has a reputation beyond reputeBeachin_240 has a reputation beyond reputeBeachin_240 has a reputation beyond reputeBeachin_240 has a reputation beyond repute
The ECU only takes readings from the O2 sensor in closed loop mode, which is cruising and idle. If you're bogging on acceleration (open loop, where the ECU takes readings from things like the TPS, MAF, etc), it's not going to be an O2 sensor problem.
Old Jun 17, 2008 | 07:48 AM
I'm leaning toward a TPS or MAF problem, probably MAF. Either sensor can be off enough that it makes the engine run like crap but not trigger an out-of-range fault in the ECU.
#1eghatch
Dec 22, 2007 08:12 AM
jt223539
May 18, 2007 06:31 AM
Wickedy Wick
Apr 30, 2006 10:19 AM
Wickedy Wick
Jun 13, 2004 09:04 AM
