spun rod bearing
Old Feb 19, 2008 | 06:54 PM
WqYn3's Avatar
repping that gR
WqYn3 WqYn3 WqYn3 WqYn3 WqYn3 WqYn3 WqYn3 WqYn3 WqYn3 WqYn3 WqYn3
Default Re: spun rod bearing
Originally Posted by crxdudesi
The dude said he didnt drive it with a spun bearing.
he had to have.
Originally Posted by Sandfrog
uh, driving it is the only way to spin a bearing unless he was bouncing the tach off the red line. I mean, the motor DOES have to be running. And I dont think the bearings will go just from idle.
thats not the only way to spin a bearing... but you are right about it has to be running..
Old Feb 19, 2008 | 11:39 PM
Sandfrog's Avatar
Sandfrog has disabled reputation
Originally Posted by wayne
he had to have.
I'm right that it has to be running? Thanks for reassuring us. Since it's possible he was manually turning it over at 1000+ RPM by hand when it blew.... By the way, since you've now shown us Captain Obvious does exist, please explain to us how one gets a bad rod bearing other than having it at idle / revving it and/or actually driving it?
Old Feb 20, 2008 | 05:52 AM
stofficer2's Avatar
stofficer2 has disabled reputation
im in the process of repairing a sunfire engine...i drive a jetta vr6 though :-) but i revd it piss high one night and burned out my bearings. they luckly didn't spin. I pulled the motor and came to find a s**t load of engine sludge so i took the oil pump apart and cleaned it out, no shavings in there nor does it need to be replaced and then started pulling the bearing caps off....the bearings were done due to oil starvation and high reving. Both main and rod bearings. Mostly the main ones though. So i thought i was screwed...not so much. the rods and crank are perfectly fine. bought some new bearings for 90 dollars and now putting them back in along with everything else. Just pull everything including rods and crank and take it to a machiniest and have him inspect it and see what needs to be done. the rods can be bent, the crank can be scored so you need to watch out. good luck.
Old Feb 21, 2008 | 11:38 AM
Audio's Avatar
#Trendy
Audio Audio Audio Audio Audio Audio Audio Audio Audio Audio Audio
it ran me about 500 in machine work on my b18c1 to bore/hone/deck/hottank/mic the crank
and 450 on some pistons and 320 on rods. Then i fully built the head as well. all depends what you want to do
Old Feb 21, 2008 | 12:11 PM
crxdudesi's Avatar
crxdudesi has disabled reputation
It aint worth all that to me I thought maybe get a motor cheap and maybe i could of rebuild it cheap but probaly not.
Old Feb 21, 2008 | 01:01 PM
sleeper99ex's Avatar
ready for your mom
sleeper99ex has disabled reputation
i rebuilt my b18 for around $300. i have most every thing needed to do it. and i might be able to rebuild yours for cheaper. i have almost 15000 miles on mine now and it sees red line almost every shift. and it is my daily driver.
Old Feb 21, 2008 | 02:11 PM
forced4gsix3's Avatar
forced4gsix3 has a reputation beyond reputeforced4gsix3 has a reputation beyond reputeforced4gsix3 has a reputation beyond reputeforced4gsix3 has a reputation beyond reputeforced4gsix3 has a reputation beyond reputeforced4gsix3 has a reputation beyond reputeforced4gsix3 has a reputation beyond reputeforced4gsix3 has a reputation beyond reputeforced4gsix3 has a reputation beyond repute
Rod bearings go from lack of oil. So do mains. Unless you cant count and put your motor together wrong. In this case your clearances are fucked.
Old Feb 21, 2008 | 04:11 PM
crxdudesi's Avatar
What it is I found a real cheap motor and i just wanted to rebuild it for cheap and put it in like a hatch or something but i didnt want to have to bore the motor or buy a crank or do anything big to the motor. Just to put the word out there I got a 97 Cadillac Deville with only 95,000 miles on it runs grear nothing is wrong with the car it has heated seat its got digital gauges,leather interior the car is green if anybody is interested Pm me and I can send pics in the next day or 2.It's a real good car.Really aint worried about selling it for a couple of weeks.
Old Feb 21, 2008 | 04:20 PM
Jarrod's Avatar
braap braap
What motor is it? LS or B20? 500 dollars can have you a complete running one.
Gs-R or Type R motor? I'd try to rebuild it.
Some things aren't worth fucking with, unless your going to shoot for higher horsepower levels.
Old Feb 21, 2008 | 04:39 PM
crxdudesi's Avatar
it is a 93 b18a1 motor
