Spindle Nut Problem
Old Apr 7, 2003 | 04:14 PM
ef_what?'s Avatar
representyoshit
ef_what? is infamous around these partsef_what? is infamous around these partsef_what? is infamous around these partsef_what? is infamous around these partsef_what? is infamous around these partsef_what? is infamous around these partsef_what? is infamous around these partsef_what? is infamous around these partsef_what? is infamous around these partsef_what? is infamous around these partsef_what? is infamous around these parts
holy shit
Old Apr 8, 2003 | 03:57 PM
sk8rmike's Avatar
Bitches get Stitches
let me know if you're still having problems
i have the "8 foot breaker bar from hell" sitting in my garage. takes 2 fingers on the end to break my spindle nut loose =P
Old Apr 8, 2003 | 04:29 PM
CRXtacy's Avatar
Pro
CRXtacy is a name known to allCRXtacy is a name known to allCRXtacy is a name known to allCRXtacy is a name known to allCRXtacy is a name known to allCRXtacy is a name known to all
yeah im gonna try this 32mm box end wrench i bought yesterday, but if that doesn't i might put the bitch-be-cool bar on it!
Old Apr 8, 2003 | 07:14 PM
1slowCRX's Avatar
1slowCRX is an unknown quantity at this point
I do not recomend heating them up unless you want to buy a new wheel bearing......heating of the hub tends to f**k the wheel bearing. Just soak that biatch in some wd-40 get a long ass breaker bar and hope for the best.
Old Apr 8, 2003 | 07:42 PM
urvtecs2slo's Avatar
i like prom.
pb blaster, heat, and the air hammer.
Old Apr 8, 2003 | 08:42 PM
Ninety7GSX's Avatar
No Name Who?
Ninety7GSX has disabled reputation
Why don't you just unbolt the upper and lower control arms and flop it to the side?
Thats what I did on the passenger side of my car cause it wouldn't come out. If you keep messing with it you might end up having to replace it. Of coarse it will eventually have to come out but, you know save it till it needs to be replaced.
Old Apr 9, 2003 | 11:01 AM
THE BEAST's Avatar
SPAWN OF A NEW OP!
THE BEAST is an unknown quantity at this point
try heat and a REAL IMPACT....like one that Chris Tucker has...it sounds like a HARLEY!!!
I had the same problem, but ended up rounding out the nut...I had to cut it off....THAT WAS A BITCH!!
GOOD LUCK!
Old Apr 9, 2003 | 12:45 PM
CRXtacy's Avatar
Pro
i would do the flip down thing but the axel has to come out of the hub because the teg axels have to go in i didn't think id need a new wheel bearing because of the heat. because doesn't it get hot anyways?
Old Apr 9, 2003 | 06:54 PM
Ninety7GSX's Avatar
No Name Who?
I would think the heat from a torch would burn up all the grease and if not regreased the bearing would go bad. But, I don't think it would ruin the bearing on its own. But, I'm not sure.
Old Apr 9, 2003 | 06:58 PM
CRXtacy's Avatar
Pro
true .i was gonna repack them anyways since im that close to them. Thanks for everyone's help
