Spindle Nut Problem
Old Apr 6, 2003 | 02:10 PM
CRXtacy's Avatar
Pro
CRXtacy is a name known to allCRXtacy is a name known to allCRXtacy is a name known to allCRXtacy is a name known to allCRXtacy is a name known to allCRXtacy is a name known to all
Default Spindle Nut Problem
I can't get my spindle nuts off my axels. I broke 2 Craftsman breaker bars and i tried an impact. No luck. Any ideas? I have to get them off before my motor gets here!
Old Apr 6, 2003 | 03:20 PM
The real Ryan's Avatar
Type-R; Tight Car
The real Ryan has disabled reputation
it doesnt tell you how in the honda book?? sorry had to say it for my last thread you tryed to flame
Old Apr 6, 2003 | 03:24 PM
nickyroo's Avatar
Default Re: Spindle Nut Problem
holy shit dude lol.
have you tried heating them up?
Old Apr 6, 2003 | 03:34 PM
CRXtacy's Avatar
Pro
no i have to get another breaker bar first. but heating them might work thanks.
Old Apr 6, 2003 | 05:18 PM
thelastmirage's Avatar
thelastmirage is an unknown quantity at this point
first of all how big is the breaker bar? what we did in my friends hatch was to put 3 in 1 multi purpose oil on it and use a breaker bar with a long as extension on it (a iron piep will do fine) and put brute strength into it.
Old Apr 7, 2003 | 02:01 AM
Mr. Rooney's Avatar
Registered Offender
Mr. Rooney is an unknown quantity at this point
Default Re: Re: Spindle Nut Problem
this will fix it (100%).
Old Apr 7, 2003 | 04:22 AM
ToyotaTechGeek's Avatar
brake/steer/throttle
air hammer, chisel point
impact wrench
did you 'undo' the 'crimp'?
Old Apr 7, 2003 | 05:24 AM
ef_what?'s Avatar
representyoshit
ef_what? is infamous around these partsef_what? is infamous around these partsef_what? is infamous around these partsef_what? is infamous around these partsef_what? is infamous around these partsef_what? is infamous around these partsef_what? is infamous around these partsef_what? is infamous around these partsef_what? is infamous around these partsef_what? is infamous around these partsef_what? is infamous around these parts
i used a like a 2.5-3 ft breaker bar w/.5 in. drive and bought a axel nut remover for my honda. set it parallel to the ground and jumped on that bitch no problem after that. try having someone hold down on your brakes, preferably someone pretty light if your car is jacked.
Old Apr 7, 2003 | 08:07 AM
CRXtacy's Avatar
Pro
Yeah my friend was holding the brakes and the axel wasn't budging. Yes we uncrimped the nut. Tried and impact with 150psi. I've tried eveything but heat and im counting on that. We put pb blaster and wd 40 on those bitches. The breaker bars WERE about 2 and a half feet long with a piece if 6 ft exhaust pipe on the end of it. You could see the breaker bar bend before it broke. I've never seen any spindle nuts as beast as these!
Old Apr 7, 2003 | 03:12 PM
mini-meturbodx's Avatar
registeredbeerdrinkr
mini-meturbodx is an unknown quantity at this point
put some stank on it
