Some Honda motor swap questions
Ok I know nothing about hondas really, and im asking for a friend.
He has a 91 accord thats an auto and blown motor. Its a clean car and he wants to keep it.
The donor car is a 92 integra with the 1.8 dohc? and manual trans. The body is beyond repair or he would do that instead, but the car runs great.
What he needs to know is what is required for the swap and if its possible without too much customizing. His main questions was which PCM to use due to the different trans/motor combo's, and if the wiring harness had to be swapped too?
He would like to keep the slushbox instead of swapping the manual in, but will swap if he needs to. The reason is the wife usually drives it and she hates manuals.
anything is doable, but that job is going to require WAAAAAAAAY too much work.... not to mention the fact that B-series' dont realy make sense in accord/preludes etc. an F22 is super cheap. good luck
take the b18, sell the full swap on here for about 700 then buy a full f22 swap, you should have about 200-250 left over since its really inexpensive and you can use that money to do a 5 speed conversion
