Smoking Single Vtec
Old Jan 4, 2007 | 06:38 AM
Yamamaha's Avatar
misunderestimated
Yamamaha has disabled reputation
Default Re: Smoking Single Vtec
Originally Posted by norfolksfinest
White is often coolant, you may have a leaky headgasket. If that's not it, it may be oil smoke and you may have damaged valve stem seals.
coolant is often a darker color either a gunmetal/black mixed with green and you could smell it too. white smoke is oil which usually doesnt have a strong scent, you may have to put new piston rings in or as he said valve stem seals
white is oil? I thought blue smoke was oil, white is coolant, and black is fuel...
and btw, arent there certain ways to distinguish wether its a certain part of the motor when the smoke occurs? For example, typically, when the car steadily burns oil and even more during load, its the piston rings...
as to when the car only kicks out some blue smoke during the startup then more than likely its the valve seals?
Old Jan 7, 2007 | 03:37 PM
bLu92bUbbLe's Avatar
bLu92bUbbLe has disabled reputation
ok...thanks....i changed sum stem seals and the gasket....ill c 2morrow wat happens...
Old Jan 7, 2007 | 07:07 PM
idriveahonda's Avatar
Shooting 63's
Ummm, thats wrong.
White is coolant, normally due to faulty headgasket or the head not properly seating on the block.
Old Jan 14, 2007 | 07:42 PM
Ok. . . I Changed The Headgasket. . . Replaced All The Exhaust Valve Seals And Valves. . . The Intake Seals Look Okay. . And I Put A New Pcv Valve On. . . She Still Smokes. . It Smokes Very Littlle 2 None When Idling. . Wen I Take Off It Barely Smokes But When I Hit It. . Thats Wen U See The Smoke. . .i Dnt No Wat Else 2 Do. . . Theres No Oil On The Plugs Or N Da Cylinder. .
Old Jan 15, 2007 | 04:31 PM
Bump. . Help Me Out
Tim-Tim
Want to Buy / Trade ARCHIVE
Jan 29, 2008 07:19 PM
bLu92bUbbLe
Dec 27, 2006 05:41 AM
