Single cam turbo questions.
Old Oct 4, 2007 | 06:53 PM
  #21
idriveahonda's Avatar
Shooting 63's
Default Re: Single cam turbo questions.
Originally Posted by mini-meturbodx
I used to have a 98 EK and went through 5 motors before I perfected the tune.(t3t04)Turbonetics Turbo, Rev hard manifold, Tial WG @10-16psi Depends on what mood I was in.
I STILL went throgh 4 More because of 5th gear boost. Shit catching on fire under the hood, after I send 2 rods through the block and one into the oil pan. Its going to happen regardless, unless its LOW compression. BTW The best SOHC setup I did was the Y8 bottom end and the Y7 head. 16psi For a good 9 months till I got stupid one Night... also did 13.20 w/ street tires@16psi.
What kind of power was it making with that last setup? Was it stock bottom end and stock head?
Old Oct 4, 2007 | 07:27 PM
  #22
B-Well's Avatar
I Love to Hate
That turbo was tiny Levi. That ish spooled up and blew off in first without even getting on it.
I'll chime in with my single-t setup. Stock y7 with 9 psi making 190.=)
Anyway,not to hijack the thread but when you comin back down here?
Old Oct 4, 2007 | 07:52 PM
  #23
92EH3's Avatar
92EH3 has disabled reputation
get some vitaras and eagles and slap on some headstuds and call it a day
Old Oct 4, 2007 | 08:04 PM
  #24
Shooting 63's
Or Vitara's and Tuner Toys, save some money, and have rods by the exact same manufacturer...
Old Oct 4, 2007 | 08:06 PM
  #25
Shooting 63's
What the hell are you talking about? That little thing didn't blow off in first til 4k plus...don't know if I couldn't hear it...or it just didn't. Don't hate.
I'll be back next Friday, in which I will be in my buddies garage ripping his LS head off his DA. Will be getting a new headgasket, and making sure he didn't fuck anything up when he snapped his timing belt.
So next Friday...the 12th, and then the following Thursday the 18th. Both times through the weekend. Hit me up haha.
Old Oct 4, 2007 | 08:13 PM
  #26
B-Well's Avatar
I Love to Hate
i'm sayin that thing spooled up quick.
I'll hit you up. you gotta come out and chill with the "crew." ha
Old Oct 5, 2007 | 03:57 PM
  #27
sohc_mshue's Avatar
Originally Posted by important
haha trust me im staying at 9 or lower.Will prolly get a boost controller too just for crusing matters,just turn it way down for safety.
I run 15psi with a t04e 57 trim on my stock motor no problem and i've been running 15psi from my old smaller vf39 for some time. With the right tune you can go above 9psi. Why not just go with a stock z6 block so your compression is 9.2:1? The higher compression doesn't have anything to do with the reliability of the motor. It has to do with how much power your are limited to with the octane gas that is available to you. If you can get it down to low 9's then you can run plenty of power on 93 octane.
Old Oct 5, 2007 | 05:58 PM
  #28
important's Avatar
important is an unknown quantity at this point
well im limited to motors,people are asking crazy amounts for a z6 block.So i guess ill be stuck at a 11.1:1 ish compression hopefully a lottt lower,and i run 87 octane?
Old Oct 6, 2007 | 10:37 PM
  #29
99EJ6T's Avatar
Boosted F2B
Oh no it blew cause 5th gear boost is not good.'egts got way to high'.
ecu adds timing when placed in 5th. thought this was common knowledge?
nice.
i run 87 octane?
nope. it will detonate, to much cylinder pressure when dynamic.
why not find a A6 block? close enough to the same block, just add the z6 oil pump to the a6 block.
also you should not boost a d16 engine with a bigger then 75.5 bore (with stock sleeves), cylinder pressures will crack the sleeves very quickly.
BTW: i picked up a stock z6 for $200 back in june.
Old Oct 9, 2007 | 05:18 PM
  #30
kingofboost's Avatar
kingofboost kingofboost kingofboost kingofboost kingofboost kingofboost
i want to boost my single cam but sounds like a lot of work
