S2000 heads, chime in. (Hardtop issue)
Old 06-17-2009, 07:35 AM
Slammedxpert
SortaFlush's Avatar
Default S2000 heads, chime in. (Hardtop issue)
Alright, so I have the mugen replica hardtop. (This one)
well, when it rains the hardtop leaks. I'll get drips coming in from both sides. The windows dont seal properly as if they are off track (which they arent, they seal perfect with the soft top) It has the rubber weather stripping all the way around it, but I was curious as if anyone else has had this problem and if they fixed it? Any suggestions? (Cant put soft top up for rain/it has a tear and forget replacing it) I also get wind noise above 65mph if windows are rolled up, but I put cardboard between the latches to pull it tighter. Any recommendations ?
SortaFlush is offline
Old 06-17-2009, 09:38 AM
fraggle rock
kyle h.'s Avatar
kyle h. will become famous soon enough
Default Re: S2000 heads, chime in. (Hardtop issue)
I've never looked at an s2000 hard top and how it mounts/latches. But I've fixed similar problems in my del sol by adjusting the mounting points, so the latch/seal is tighter.
See if you can get more clamping force. If that doesn't fix it you might want to add or remove and add some weather stripping.
kyle h. is offline
Old 06-17-2009, 10:18 AM
Slammedxpert
SortaFlush's Avatar
Clamping it more wont do it.
Old 06-17-2009, 10:59 AM
SG
C16EFSedan's Avatar
C16EFSedan has disabled reputation
Dont purchase replicas?
C16EFSedan is offline
Old 06-17-2009, 11:22 AM
Slammedxpert
SortaFlush's Avatar
Came with the car.
Not going to spend 4k on another one, either.
Old 06-17-2009, 02:21 PM
Works on S2000's.
C Ory's Avatar
C Ory C Ory C Ory C Ory C Ory C Ory C Ory C Ory C Ory C Ory C Ory
Originally Posted by I spy Psi,No?
Came with the car.
Then you may have to deal with it.
Either sell it and repair your soft top, or get a different hardtop.
My hardtop doesn't leak in the rain, and no wind noise.
C Ory is offline
Old 06-17-2009, 02:29 PM
NUMBER4
fish's Avatar
fish fish fish fish fish fish fish fish fish fish fish
Shin etsu grease might help a little. I've got a pretty big tube of it. I'll try to get it to you sometime this weekend.
Shin etsu works great for small leaks. I haven't had any problems with the soft top on my AP2, but had some minor leaks on my AP1. A good rubbing of shin etsu took care of it. All it does is make the rubber swell a little, and gets rid of any dry spots where water can be slipping by.
fish is offline
Old 06-17-2009, 03:09 PM
Slammedxpert
SortaFlush's Avatar
Sweet, thanks Pete.
You've also got an OEM hardtop. I want one soooooo bad.
Old 06-18-2009, 01:34 PM
fraggle rock
kyle h.'s Avatar
Does the Shin etsu leave marks if handled?
kyle h. is offline
Old 06-18-2009, 02:05 PM
EMF S2K
jeremy's Avatar
jeremy jeremy jeremy jeremy jeremy jeremy jeremy jeremy jeremy jeremy jeremy
Sweet, thanks Pete.
trade some idiot out there, there's plenty
jeremy is offline
Quick Reply: S2000 heads, chime in. (Hardtop issue)
