S2000 heads, chime in. (Hardtop issue)
Alright, so I have the mugen replica hardtop. (This one) http://i220.photobucket.com/albums/d...205606e673.jpg
well, when it rains the hardtop leaks. I'll get drips coming in from both sides. The windows dont seal properly as if they are off track (which they arent, they seal perfect with the soft top) It has the rubber weather stripping all the way around it, but I was curious as if anyone else has had this problem and if they fixed it? Any suggestions? (Cant put soft top up for rain/it has a tear and forget replacing it) I also get wind noise above 65mph if windows are rolled up, but I put cardboard between the latches to pull it tighter. Any recommendations ? :( |
Re: S2000 heads, chime in. (Hardtop issue)
I've never looked at an s2000 hard top and how it mounts/latches. But I've fixed similar problems in my del sol by adjusting the mounting points, so the latch/seal is tighter.
See if you can get more clamping force. If that doesn't fix it you might want to add or remove and add some weather stripping. |
Originally Posted by kyle h.
(Post 5372196)
Dont purchase replicas? :dunno:
Originally Posted by C16EFSedan
(Post 5372459)
Not going to spend 4k on another one, either. |
Originally Posted by I spy Psi,No?
(Post 5372550)
Came with the car.
Not going to spend 4k on another one, either. Either sell it and repair your soft top, or get a different hardtop. My hardtop doesn't leak in the rain, and no wind noise. :dunno: |
Shin etsu grease might help a little. I've got a pretty big tube of it. I'll try to get it to you sometime this weekend.
Shin etsu works great for small leaks. I haven't had any problems with the soft top on my AP2, but had some minor leaks on my AP1. A good rubbing of shin etsu took care of it. All it does is make the rubber swell a little, and gets rid of any dry spots where water can be slipping by. |
Originally Posted by fish
(Post 5373162)
Shin etsu works great for small leaks. I haven't had any problems with the soft top on my AP2, but had some minor leaks on my AP1. A good rubbing of shin etsu took care of it. All it does is make the rubber swell a little, and gets rid of any dry spots where water can be slipping by. Sweet, thanks Pete.
Originally Posted by C Ory
(Post 5373138)
Then you may have to deal with it.
Does the Shin etsu leave marks if handled?
(Post 5373266)
Sweet, thanks Pete.
You've also got an OEM hardtop. I want one soooooo bad. |
