RPM gauge is going crazy!! What do I do??
Old Dec 18, 2006 | 01:51 PM
RoAzn757's Avatar
RoAzn757 has disabled reputation
Default RPM gauge is going crazy!! What do I do??
Yea I got an 95 Integra and everytime I start it the rpm gauge goes up and down and this happens when it is warmed up also. What could this be and what could I do about it? Thanks fellas.
Mark
Old Dec 18, 2006 | 02:25 PM
integrarj's Avatar
Default Re: RPM gauge is going crazy!! What do I do??
is just the gauge goin up or is your car reving up and down
Old Dec 18, 2006 | 06:19 PM
Slooby's Avatar
TAINT PUNCHER!
It sound like you idle air control valve to me. I had a civic that would do that as well.
Old Dec 18, 2006 | 06:23 PM
awd4lyfe's Avatar
awd4lyfe has a reputation beyond reputeawd4lyfe has a reputation beyond reputeawd4lyfe has a reputation beyond reputeawd4lyfe has a reputation beyond reputeawd4lyfe has a reputation beyond reputeawd4lyfe has a reputation beyond reputeawd4lyfe has a reputation beyond reputeawd4lyfe has a reputation beyond reputeawd4lyfe has a reputation beyond repute
my car does that to, it also does it when comming to a stop but i just dont pay any attention to it
Old Dec 18, 2006 | 06:33 PM
murphy660's Avatar
murphy660 is infamous around these partsmurphy660 is infamous around these partsmurphy660 is infamous around these partsmurphy660 is infamous around these partsmurphy660 is infamous around these partsmurphy660 is infamous around these partsmurphy660 is infamous around these partsmurphy660 is infamous around these partsmurphy660 is infamous around these partsmurphy660 is infamous around these partsmurphy660 is infamous around these parts
is the idle actually irratic or just the cluster? could be a stuck open/bad iacv if the idles irratic
Old Dec 19, 2006 | 04:16 AM
Zimzallabim's Avatar
Registered Baller
Zimzallabim is an unknown quantity at this point
idle air control valve, maybe, happened to me or bad wires or loose connection
Old Dec 19, 2006 | 05:37 AM
GaRn's Avatar
Usually, cleaning the IACV can solve the problem, if thats what it is.
Old Dec 19, 2006 | 08:29 AM
RoAzn757's Avatar
So how do I clean the IACV or how do I replace it?
Thanks,
Mark
Old Dec 19, 2006 | 10:27 AM
Hondas_Only's Avatar
Do You Want More?
Hondas_Only Hondas_Only Hondas_Only Hondas_Only Hondas_Only Hondas_Only
you gotta answer the question first... is the engine revving or just the gauge moving?
the IACV is right behind your intake manifold on your teg. has three bolts. unbolt them... pull it off, and spray some carburator cleaner in there... you will see all the black junk coming out. put it back on and you should be good. check out team-integra for pics and a better description
Old Dec 19, 2006 | 10:41 AM
RoAzn757's Avatar
it is the engine so it is right behind the intake manifold. What does it look like?
