Rough Idle help guys/gals
Old Mar 4, 2004 | 05:30 PM
TheGentleArt's Avatar
DA LEPRAHKAHNZ GOLLD
TheGentleArt TheGentleArt TheGentleArt TheGentleArt TheGentleArt TheGentleArt TheGentleArt TheGentleArt TheGentleArt TheGentleArt TheGentleArt
Default Rough Idle help guys/gals
Hey when my car is in nuetral it feels like it is going to choke out... i just had it tuned up like 2 weeks ago. new wires/plugs ( good kind to ) and no problems til yesterday night... i did also just replace my elbow to my intake... could this have effected anything? also feels like it is going to choke out when 1st gear engages... its really pissing me off
Old Mar 4, 2004 | 06:01 PM
gear's Avatar
Die reinste Bösen.
Default Re: Rough Idle help guys/gals
check your plugs.... i had carbon fouled plugs, ran like ass. good luck
Old Mar 4, 2004 | 09:43 PM
94XRolla's Avatar
1point8
94XRolla has disabled reputation
not sure about veedubs but check to make sure no vaccuum (sp) hoses came disconnected when you did that... and did you have stock intake before? maybe reset your ecu if its self programming....
Old Mar 5, 2004 | 08:03 AM
cootees's Avatar
Ivy Tadita
cootees will become famous soon enoughcootees will become famous soon enough
Vacumn lines, did you adjust the timing when you tuned it?
Old Mar 5, 2004 | 08:06 AM
CHAHONDA's Avatar
corona connessuer
did you put in adifferent heat range plugs? that could make them get fouled and run like shit
Old Mar 5, 2004 | 08:08 AM
Carter's Avatar
nannerpus, nannerpus
something like this happened on my jetta. check your mass air sensor (right after the filter), make sure it's clean.
Old Mar 5, 2004 | 07:34 PM
Neo Xian Wu's Avatar
Dont Be Scared Homie
since you removed your intake, i'd check for any loose vac hoses or connections. i remember when i put the intake on my car back on after replacing the head and i forgot to tighten one of my intercooler clamps. car wouldn't boost for shit and scared the piss outta me.
Old Mar 6, 2004 | 05:46 AM
hey thanks guys sorry for taken so long to get back to yall one of my plug wires are bad ( sparking in the whole so its grounding its self out ) geon is replacing the fucked one for free so its all good thanks brothas!
Old Mar 10, 2004 | 08:48 AM
GotB00stPsi's Avatar
GotB00stPsi is an unknown quantity at this point
make sure ur mas air flow sensor and messed up, check timing, possibly o2 sensor?
are you shooting any codes?
Old Mar 10, 2004 | 06:02 PM
lil late homie
sikwitit
Sep 23, 2008 05:34 AM
efhatch23462
Apr 3, 2008 09:29 AM
98hondakid
Apr 12, 2007 06:38 AM
NEO_WRX
Sep 27, 2006 07:03 AM
HondaCRXsiHatch
Feb 2, 2005 06:57 PM
