Rear disc conversion??
Old Nov 21, 2004 | 12:26 PM
carate's Avatar
carate is an unknown quantity at this point
Default Rear disc conversion??
yo i got a civic dx(eg) my brakes dont really seem to stop the car...has anyone done just the rear disc conversion??by using rear civic discs, like off a ex or si??if so is the stopping power substancially better??
Old Nov 21, 2004 | 02:18 PM
MA-HALF-E's Avatar
Awesome.
Default Re: Rear disc conversion??
It's never been done, so good luck.
This might help:
http://www.honda-tech.com/zerothread?id=641639
http://www.honda-tech.com/zerothread?id=152884
Old Nov 21, 2004 | 06:02 PM
95jdmhatch's Avatar
95jdmhatch is an unknown quantity at this point
I did the rear disc conversion on my 95 cx useing the 93 si rear disks I took the whole trailing arms off and swapped the whole thing out even the e-brake it was easy but it wasnt a huge difference you also need to switch to the si/ex brake master cylinder and front larger brakes off the ex/si Which I havent done yet. Not 100% but Im pretty sure there is a size differece on the front si and front cx brakes. Everything bolts right up. Good luck I picked mine up for $65 at u-wrench it .I was at the right place at the right time they go for usually over $200 .
Old Nov 21, 2004 | 06:10 PM
95jdmhatch's Avatar
If you get those brakes for your car pm me I could help if your in the virginia beach area.
Old Nov 30, 2004 | 05:23 PM
99EJ6T's Avatar
Boosted F2B
[QUOTE=95jdmhatch]it wasnt a huge difference you also need to switch to the si/ex brake master cylinder and front larger brakes off the ex/si Which I havent done yet. QUOTE]
brake master cylinder/proportioning valve(sp)/front brakes(disc & caliper & caliper bracket)/rear brake conversion for it to work like stock.
yes, it would stop the car better since disc brakes are better then drums anyday. and in my oppinion my 90 hbk stopped better once i did the swap. plus it helps when you left foot brake during aggressive umm... driving
00si
Nov 12, 2008 06:05 PM
BrokeAssCrix
Nov 22, 2007 02:26 PM
turbofordummies
Mar 10, 2007 08:58 AM
