Really need help
ok i have a 1999 honda civic dx hatch with a y7 block and a z6 head y8 intake manifold with a p2p ecu the problem is that i keep blowing my FEI/M fuse under the hood i looked it up and i've read that it was recalled someone said for that problem and there is no answer i can find but it seems like a common problem i keep blowing the fuse ever time i turn the key now m car is stuck on the side of the road and i went thru like 10 fuses trying different ways to fix it also it started doing it a week ago and i replaced the fuse with the correct 15a fuse i found it had a 20 in its place i ran for a little while and today when i came home from work it blew before i could even shift into secound i had extra fuses on me thinking i could replace it and it start but evertime i turned the key it blew the fuse.
http://www.sparkys-answers.com/2009/...use-blown.html
Post back if this is the answer to your issue. Reading it is seems to be on par with your issue.
no its not the same fuse that guy is talking about the interior fuse mines under the hood but i got a mech. shop to look at it a reall good buddy of mine so ill post what fixed it so ppl dnt half to search so much anymore
