problem is chapping my ass
Old Sep 7, 2003 | 07:21 AM
DOHC VTEC EG's Avatar
J-Spec
DOHC VTEC EG can only hope to improve
positive
Old Sep 7, 2003 | 07:31 AM
stl2slw's Avatar
version VI
stl2slw stl2slw stl2slw stl2slw stl2slw stl2slw stl2slw stl2slw stl2slw stl2slw stl2slw
probably your timing is off, is it sluggish when you excellerate?
Old Sep 7, 2003 | 07:43 AM
J-Spec
yes very sluggish
also it is still very sluggish but just yesterday i went and turned it on and let it warm up and shti and it was not as lazy as the night before is there something to do with the springs that they are not used to the lift or something. just wondering
Old Sep 8, 2003 | 03:07 AM
NIC668's Avatar
I had this problem on a car I was working before. We did a timing belt and the exhaust turned 180 degress and we didnt notice we lined the cam gears up and everything seemed to be good. And we started it idled good but when we test drove it it have no power. I would pull the valve cover off and double check the cam postions. In my case there was two ways to put the cams in I dont know about the itr but it sounds like a cam is off. Also I would go back and make sure piston one is at tdc again. Retrace your every move it is something small and simple with the timing if you have to break it all down and redo the whole thing.
Old Sep 8, 2003 | 03:13 AM
jeff s's Avatar
why5oh
jeff s jeff s jeff s jeff s jeff s jeff s
petroleum jelly will help soothe out any friction on the purple onion.
Old Sep 8, 2003 | 12:33 PM
J-Spec
will check the timing over again thats what it probably is
fmstatic
Apr 12, 2005 08:35 PM
Durrett Syndrom
Apr 8, 2003 09:17 AM
Volkswagen
Mar 27, 2003 03:06 AM
