open downpipe. need help asap!
whats better for a turbo car?
right now it has a 3in straight pipe exhaust with a cat and resonator. ive had a few people tell me ill get better power if disconnect it and just run a open downpipe, then others tell if with it open i could spin a bearing or throw a rod. can anyone help? which is better? |
Re: open downpipe. need help asap!
depends on how you're tuned, really. some people have different opinions on the matter.
of course, you should probably post the setup. i'm assuming it's a terrible looking honda that copies someone else's style. but badly. |
Originally Posted by itsoverton
(Post 6437740)
of course, you should probably post the setup. i'm assuming it's a terrible looking honda that copies someone else's style. but badly. sadly.. he beats the shit out of it |
Originally Posted by yanko 15
(Post 6437756)
its actually a decent car aesthetically and mechanically
sadly.. he beats the shit out of it when i first got it yes. but ive calmed down with it now i shift at 2500-3000 just riding around. i havent hit full boost all week. |
Originally Posted by Corbzin
(Post 6437787)
Motor:
B18B1 eagle rods JE pistons Inline Pro head gasket golden eagle block gaurd ARP head studs Innovative solid motor mounts STR cam caps 3 inch exhaust all the way back 170psi across the board when compression tested Turbo kit: Inline Pro manifold Tial 38mm RC 550cc injectors Inline Pro inercooler piping Precision 350whp intercooler Garret .60 trim turbo Greddy type s bov Hondata 3 bar map sensor Tuned on 17 PSI |
(Post 6437740)
of course, you should probably post the setup. i'm assuming it's a terrible looking honda that copies someone else's style. but badly. It depends on how you're tuned and turbo size. A smaller turbo is actually more efficient with a little back preasure. Edit: Running an open DP is not going to cause you to throw a rod, or spin a bearing. |
(Post 6437790)
congratulations, lets see how long you keep this one in one piece
(Post 6437794)
hopefully a while since its paid off. i can dump money into it to make it clean.
(Post 6437806)
you have to make money in order to "dump" money into it. although "dump" is a relative term.
