Ooops!
If it got hot enough to melt plug electrodes, its probably safe to say your rings are fried as well , especially from the results of the compression test with 0 psi in #1 cylinder. I would do a complete tear down and inspect.
Easy way to check head gasket is to check oil. If it looks like a slim fast milk shake it's possible head gasket.
I doubt valves either. you'd definatly know if you took out a valve.
1.5mm Power Enterprise Headgasket with arp head studs...Compression numbers last week were 125, 125, 120, 125....0, 115, 90, 95 as of yesterday and that kid is still trading me his s2k for it...it that falls through, looks like I'll be buying a new engine, but this time, I'm getting AC to work, and I'm getting the s15 sr20...
Oh, and it burnt 2 quarts of oil in about 60 miles...smokes under acceleration and sounds like a subaru...Did I mention it hisses at me everyone once in a while? At the beginning of the gear, it will go "psh" real quick, like air or something is forcing it's way out...and it's leaking oil...so that's why I say the headgasket...
Well, it didn't leak oil until this happened..where else could it come from unless there's a hole in the block...I've seen oil blown out of a head before...
