No lights coming on in my 01 Acura Cl-S Cluster NEED HELP
ig oggggg
Re: No lights coming on in my 01 Acura Cl-S Cluster NEED HELP
loll at "taterguy06"
check your grounds??
well...check to see if something s grounding out that shouldnt be
yes, everything comes on...like when my lights are off , all the automative drives illuminate, sports shift numbers and my odometer is light up, ok when i turn my lights on everything goes off, clock light and auto drive lights, and sports shift light goes off...i just got finished ripping apart the dash and all the grounds look fine... im thinking either its the actual light switch or cluster?
If everything works properly but then stops working properly when you turn the switch, I'd say it's the switch. If it was a ground problem, etc., then it really wouldn't work at all.
