Need some help from my honda lovers
ok. I got a swap(Frankinstien) B20 block, CRV, with a B16a3 head. This was a pretty badass car when everything was running right, but after me and my dad removed the AC system(which im pretty sure that has nothing to do with it) and my dad took the air intake off and sprayed manifold cleaner into the manifold it started screwing up. I go to start it idols just under 2500 rpms. thats way to high. I drive and it runs fine, but after it runs for a little bit and im not moving(at idol) rpms goes up and down. Ive already replaced the air control valve and it didnt change it and its not the throttle position sensor either..bad injectors? need some help. thanks. its for sale on vadriven so check it out.
im assuming that yall didnt take the precations of covering the bottom hole so as not to spray the cleaner in there...?? because that WOULD definitely screw som things up, but likewise, back when i had mine, it did the same thing...it could be a number of things.....
sounds like ur fast idle valve got messed up from the manifold cleaner. ur describing the exact symptoms of a fast idle valve faliure. see if ur car has it and if so try that and see wat happens.
