need help with swap
Old 06-28-2006, 02:47 PM
slowcivic's Avatar
slowcivic is an unknown quantity at this point
Default need help with swap
im tring to but an ls in my 98 hatch. the motor had an auto tranny on it so the wiring harness is useless i think? so i need to know what all i will need like, motor/tranny mounts
wiring harness
axles
ecu options
thanks for any help
slowcivic is offline
Old 06-28-2006, 03:14 PM
import mechanic
sucio7's Avatar
sucio7 has disabled reputation
Default Re: need help with swap
use ur original harness to the vehicle
use the orinal mount for the transmission
depending the year of the ls pm me for the rest
sucio7 is offline
Old 06-29-2006, 08:13 AM
aacjohnc's Avatar
if im not mistaken you should be able to use all your mount but the rear tranny mount. i think you need one from a 00 si civic for it to mount. you should be able to use your old wire harness. and what obd1/2 engine are you using ? try to use obd2 is you dont want any wiring problems. go to 6thgencivic.com i think there is a bluid on it there. if its not i printed it out a while ago and i can send it to you .
aacjohnc is offline
sTohc4door
Engine / Exhaust / Drivetrain
02-18-2009 05:23 PM
vtec2.0
10-31-2008 11:10 PM
Quick Reply: need help with swap
