NEED HELP!!!!!! problems with my eg hatch
Old Jun 5, 2005 | 02:14 PM
sir92hatch's Avatar
sir92hatch has disabled reputation
Old Jun 16, 2005 | 08:16 AM
Turbo T's Avatar
Turbo T is an unknown quantity at this point
Default Re: NEED HELP!!!!!! problems with my eg hatch
Are u usre u dotn have a lose wire some where rubbin on metal shorting it out or anything like that?
Old Jun 16, 2005 | 04:01 PM
Loose connector, loose ground, I wouldn't suspect a pinched wire or anything unless you've had the cluster out. The lights and gauge power are have seperate circuits inside the cluster, so something like a loose power or ground could affect one and not the other. Grab a manual, pop the cluster out, and check that you have power and ground continuity where you should on the incoming harness.. Happy hunting..
Old Jun 18, 2005 | 08:00 PM
Tiny Tim's Avatar
RIP MEAST
Tiny Tim will become famous soon enough
ground maybe
Old Jun 18, 2005 | 08:18 PM
gear's Avatar
Die reinste Bösen.
gee whizz.
Old Jun 27, 2005 | 03:50 AM
sir92hatch's Avatar
thinks guys for the info the problem ened up being the back up light fuse was burnt out so i replace that and now the cluster works
DORKO
Sep 16, 2008 11:58 AM
nogo1231
Jun 22, 2008 01:25 PM
95lsintegra
May 23, 2006 07:55 AM
DirtyEF
Mar 24, 2006 08:19 PM
hatch_this
Mar 9, 2003 08:58 PM
