Need help pick correct ECU...
I have a D15 block with y8 head and it going in to an 89 hatch...What ECU do i need? I think a p28, but i wanted to ask to be sure...thanks.
corona connessuer
the p28 would be ideal but you would have to get an adapter harness made. fabrik8 makes them. i am assuming that you still have the crappy d15 fuel injection as well? you will need to upgrade to the si intake manifold and fuel injection in order to be able to use the p28 computer.
or you can forget the rest of this and do the easy way and just wire in an msd rpm switch set at 5000 rpm and just go from there. while this is not the most ideal setup, your vtec will still function.
