need help for h22 swap in eg
im about to put in an h22 in a 93 coupe. im going to buy avid mounts but the only problem is im putting an accord tranny on the h22 and the mount will not fit. (tranny side).. does anybody have an advice for me??
and i have heard that you can put a 1990 accord half-shaft and 91-93 axles and that will work so you dont have to buy up graded axles...
any advice will help thanks!!!
Re: need help for h22 swap in eg
i dont know about using the accord tranny and weather or not the avid mount will work...im pretty sure it will but not completely. As far as the upgraded axle goes no matter what half shaft you use u will not be able to go with a stock axle. To make stock axles work you have to mate a integra axle with a prelude or accord axle due to the size of the splines in the hub. if you are looking for the cheapest upgraded axle to make the swap easy you should check into some gator racing axles
i want the gearing long b/c im planing on going boost!! unless i can find someone who has a cheap h22 tranny then ill buy it. b/c i want to go all motor on a 100 shot.. but does anybody know where an cheap tranny is with no grinds??
