need help asap
most honda tie rod ends are like 25 bux from bap geon. there is a large locknut behind the tie rod end that you need to break free, and then you can turn loose the tie rod end by putting a wrench on the inner tie rod to hold it and on the outer tie rod to turn it off. it's really easy you just have to look at it. and yes, a worn severely worn out tie rod end will not only cause your wheel to excessively shake, but it can also wreak havoc on your wheel bearing and i would most definitely take a look at it after you put the new tie rod end on.
Originally posted by bustedhatch88
how do you fix a tie rod end? when i slow down it shakes badly. im pretty sure what that is, so how do i fix it? thanks for the help
Gold Eg
Want to Buy / Trade ARCHIVE
Nov 13, 2008 07:12 AM
