Need help from Acura Tech. TPS
I currently sent my Throttle body from my 03 CLS out and got it bored. Got it back and my Check engine light came on for High Circuit Input (p0123). I reset the Light and set the TPS at .45V. Can fan fine and dandy. Did a 3rd gear pull (yep 6speed!) and light comes on....p0123 again. I'm pretty sure that the TPS is fine. Could it be that I will need to lower the voltage a bit lower? say .40v? specs on voltage for TPS closed? any help or advice would be great. thanks!
Eddie
Eddie
dont just check it closed you also need to check it at full throttle. Hold it open and see what it reads, it should be just under 5v if it is over it is set wrong. Also if it is to low like under 4v at full throttle. PM sent.
Hybrid-Garage.org
Hybrid-Garage.org
trying lowering it to .42 but i doubt that'll help much.
check the voltage while opening the butterfly slowly. check for any irregular readings. you might have a busted tps.
Suspension / Brakes
Aug 3, 2011 01:17 PM
517716
Dec 14, 2008 11:52 AM
