need help!
Old Apr 21, 2004 | 10:42 AM
blkmjk's Avatar
the"V8nightmare"
blkmjk is an unknown quantity at this point
Default need help!
swaping an ls in a 94 hatch cant get mounts to line up . do i need hasport mounts? i heard that i dont? any help would be nice .thank you ps this isnt drew. its brandon.
Old Apr 21, 2004 | 12:01 PM
Bert's Avatar
hybrid no more :(
Default Re: need help!
couple questions:
what mounts are you using?
which rear bracket are you using?
what year motor are you installing?
what kind of tranny? (hydro cable)
Old Apr 22, 2004 | 07:30 AM
blkmjk's Avatar
the"V8nightmare"
stock,integra,93, s1 cable. ??? found out yester day that we need hasport mounts to get it to work .
Old Apr 22, 2004 | 08:19 AM
CHAHONDA's Avatar
corona connessuer
the transmission is wrong as well. the 94 hatch has a hydraulic clutch setup. you can get adapters to make this work though....but why would you?
Old Apr 22, 2004 | 09:54 AM
Bert's Avatar
hybrid no more :(
yes you do need hasport kit....especially for the cable tranny... you can get around this by cutting and rewelding but i highly advise you not to do this...so just don't go that direction..
93 engine difference: the hasport kit has a different driver side mount that will bolt up to the 90-93 driver side engine bracket. This bracket is 3 14mm bolts w/ one of the bolts underneath the timing belt cover...if you do not get the complete kit you will need to change this bracket to 94+ teg. i'm pretty sure that you can't even buy a partial kit so i wouldn't even worry about this..
rear bracket: there are 2 kinds of rear brackets to get... "T" and "L".... the "T" is what you need this bracket is the one for the 94+ teg...contact hasport to be definate to see which rear bracket but i'm pretty sure that this is the one you need... "L"'s are from the 90-93 tegs..
other notes: make sure you get the right axles. intermediate shaft needs to be 90-93 teg as well as the axles. you can use a 94+ axles intermediate shaft and axles but you must change out the transmission seal or your tranny will leak...the seals themselves are easy to change out but i wouldn't even bother with this and just get the right axles...
HTH
