my car is surging and I need some advice.
Old Jun 5, 2005 | 11:03 AM
lil_greencivic's Avatar
lil_greencivic is an unknown quantity at this point
Default my car is surging and I need some advice.
ok I was going to do an intake manifold swap{y7 to a y8}. I ran into problems when I noticed that I had to make my injector wires longer and also some lines longer. I figured that I would ask a friend of mine what to do. so I put the y7 manifold back on made sure every thing was put back together and then I started the car.
soon as I turned on the car it was idling way high and then it started to surge. up and down went the rpm's. know mind you I can see the rpm level cause I have a 99 dx. so I called up a friend steven and he said that it might be my throttle body gasket, cause I never changed it and I just put it back on. he also told me that I have a gasket leak. my question is will this surging thing go away once I change the gasket or is it something eles. oh I also replaced the manifold gasket. And I also looked inside my manifold and there is some condensation or some kind of liqiud. can anybody help me please.
Old Jun 5, 2005 | 11:31 AM
Default Re: my car is surging and I need some advice.
can somebody help me please.
Old Jun 5, 2005 | 05:17 PM
NastyNate's Avatar
Say somm!!!
NastyNate is an unknown quantity at this point
Sounds like a vacuum leak. Get a can of gum cutter and spray all around the intake manifold and any other place you disturbed while trying to swap manifolds. Once the surging stops or idle goes back to normal....find the area you sprayed that made it go back to normal and R&R as necessary.
Old Jun 5, 2005 | 07:09 PM
ritz's Avatar
Take a .44 Magnum. Point it at your motor. Pull the trigger.
Old Jun 5, 2005 | 08:02 PM
naw I dont want to do that. I wanna keep it build it, turbo and be done with it. I dont wanna follow the B crowd. If I see 250+ with this D I will be happy.
Old Jun 5, 2005 | 08:04 PM
zexpwrd4door's Avatar
R E U P Gang
zexpwrd4door zexpwrd4door zexpwrd4door zexpwrd4door zexpwrd4door zexpwrd4door zexpwrd4door zexpwrd4door zexpwrd4door
You got high hopes unless that motor is built. I hope to god you used a y8 manifold from an auto Ex or you are in for more then you expected with the iac valve.....
Old Jun 5, 2005 | 08:09 PM
yes I am going to fully build it. why would you say that. I am using a 5speed ex. I have not put it on yet I just put the y7 manny back on and now it acting very funny.
Old Jun 6, 2005 | 04:20 AM
CHAHONDA's Avatar
corona connessuer
like he said...you need an auto ex manifold
Old Jun 6, 2005 | 04:41 AM
but dont have an auto. I have a 5 speed. can someone explain what problems I am going to run into.
Old Jun 6, 2005 | 04:46 AM
CHAHONDA's Avatar
corona connessuer
you use the auto ex manifold and bolt the y7 throttle body to it and eveything is great. use all new gaskets too
xXThat GuyXx
Jan 5, 2009 03:33 PM
Computer_Nerd
May 25, 2007 08:33 AM
dorifto83
Apr 28, 2004 03:20 AM
