motor (cams)
Old Nov 20, 2005 | 06:53 PM
94gsrblk's Avatar
SLick InteG
94gsrblk has disabled reputation
Default motor (cams)
just got a new gsr motor wondering what the best cams out there are nowadays looking for stage 2 or 3 cams also nothing over 750
Old Nov 20, 2005 | 10:01 PM
連続注入's Avatar
Dont guess, diagnose
連続注入 連続注入 連続注入 連続注入 連続注入 連続注入 連続注入 連続注入 連続注入 連続注入 連続注入
Default Re: motor (cams)
This is really more of personal preference. Stage 2 shouldnt present much of a idle problem as 3's will. Definelty research your cams for lift and duration. Biggest thing though, lift, you dont want to have any physical contact with the piston. Defiently measure your clearances.
Pardon the spelling.
Old Nov 20, 2005 | 10:26 PM
Jarrod's Avatar
braap braap
I don't see you post much, except for the past couple of days. You seem to know your stuff pretty well.
I was gonna say pretty close to the same thing.
Another thing is, you don't want cams to big for your compression(stage 5 Buddy Clubs on stock GsR), and you don't want cams that go too high in the rpms, unless you have a tuned(chipped whatever) ecu to go up into those higher rpms, along with the valve-train.
Old Nov 21, 2005 | 05:35 AM
連続注入's Avatar
Thanks
Old Nov 21, 2005 | 07:09 AM
gear's Avatar
Die reinste Bösen.
Stage 3's are abit much and will be pretty much a waste without a bump up in compression. Stage 2's are good but Buddy Club Spec III's are better. I wouldnt just throw some cams in either without upgrading the valvetrain. You can get a pretty good deal on everything from OmniPower.
for B-Series DOHC VTEC Motors
Buddy Club Spec III camshafts
Omni Power Dual Valve Springs
for 754.99
as taken from www.omnipowerusa.com
Old Nov 21, 2005 | 08:19 AM
dahatch's Avatar
dahatch is an unknown quantity at this point
the car must be tuned with any big mod such as cams and must have good valve springs and retainers the buddy club is a good cam but the skunk pro1/pro2 cams make really good low to mid numbers and they idle preety well i tested alot of cams this year and the skunks worked in ls crank 11.5 motors and in my big 2.2ltr motors about the same
H22CIVICWIDBDY
Want to Buy / Trade ARCHIVE
Nov 27, 2008 07:05 AM
92sihatch
Nov 15, 2008 08:26 AM
