Misfiring after running out of gas
Old Oct 28, 2008 | 06:18 AM
gen4H22A's Avatar
BOXIN YOU
Default Misfiring after running out of gas
I own a automatic 95 Jaguar XJ6. I was on my way to work today when I ran out of gas. I put gas in the car, go to drive off and it bogs down really bad, wont get out of 4th gear. Check engine light is on also. What happened? do I need to reset my battery? thanks in advance
Old Oct 28, 2008 | 06:21 AM
94jdmgsr's Avatar
madmike
94jdmgsr is on a distinguished road
Default Re: Misfiring after running out of gas
I bet if you go have someone read the code it will tell you more about whats going on.
Old Oct 28, 2008 | 10:18 AM
kronikSLOW's Avatar
kronikSLOW has disabled reputation
i whould venture to say that one of your injectors are clogged after sucking up some sediment from the bottom of your tank.
Old Oct 30, 2008 | 05:29 AM
Hatch Man(GsR)'s Avatar
I drive a coupe
Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR)
a lot of times if you are throwing a transmission code your tranny will lock you into the 1:1 gear as a limp mode. You will need to clear the code and make sure there are no other problems. As far as the car bogging down, thats probably because there is no kick-down when in limp mode...
Old Nov 1, 2008 | 09:21 AM
atmdc's Avatar
やくざに成りたい
atmdc has disabled reputation
what i was thinking, clean your system dude
Old Nov 1, 2008 | 01:31 PM
95MustangGT's Avatar
95MustangGT has disabled reputation
go buy some injector cleaner. Or you can treat your car a little better with some SEA FOAM!
Old Nov 1, 2008 | 01:52 PM
PoS hYbRiD's Avatar
Old School Beast
PoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these partsPoS hYbRiD is infamous around these parts
Injector cleaner is a complete waste of money. period.
Old Nov 2, 2008 | 05:46 PM
Enigma's Avatar
Replace your fuel filter before putting any seafoam into your tank.
kronikSLOW
Aug 26, 2008 01:00 PM
dogg2k78
Aug 22, 2006 09:01 AM
SAINT240
Aug 6, 2006 08:07 AM
BlessTheMartyr
Mar 12, 2006 06:07 PM
head1st4haloz
Dec 21, 2004 04:41 AM
