Major 01 GS-R Problems
Originally Posted by 924drsleeper
No, the VTEC spool valve is not the problem.
It's a vtec solenoid..
I know what you mean, it was just funny..
Originally Posted by Fabrik8
Lol, what is a "spool valve"..? Can I make vtec spool up faster? Maybe change over to a ball bearing vtec system?
yes i will second the spool valve. If you look it up on a honda parts list that what it will say
actually here ya go
12100-P30-020 001 CYLINDER HEAD ASSY. - 1 $1514.59 $1210.91
12204-PR3-305 002 GUIDE, VALVE - 8 $8.27 $6.10
12205-PR3-305 003 GUIDE, EX. VALVE - 8 $8.27 $6.10
12210-PZ1-003 004 SEAL A, VALVE STEM (ARAI) - 8 $1.38 $0.93
12210-PZ1-004 004 SEAL A, VALVE STEM (NOK) - 8 $1.38 $0.93
12211-PZ1-003 005 SEAL B, VALVE STEM (ARAI) - 8 $1.38 $0.93
12211-PZ1-004 005 SEAL B, VALVE STEM (NOK) - 8 $1.38 $0.93
12237-P30-000 006 PIPE, CAM HOLDER - 2 $95.68 $70.61
12251-P30-014 007 GASKET, CYLINDER HEAD - 1 $78.12 $57.65
12513-P72-003 008 SEAL, R. CYLINDER HEAD - 1 $5.77 $4.25
15810-P30-005 009 VALVE ASSY., SPOOL - 1 $298.90 $220.58
15815-PR3-004 010 FILTER, SPOOL VALVE - 1 $15.87 $11.70
15816-PR3-000 011 STAY, CONNECTOR HOLD - 1 $5.03 $3.71
15825-P08-005 012 FILTER ASSY., SPOOL VALVE - 1 $15.87 $11.70
36171-P08-005 013 SOLENOID ASSY. - 1 $149.00 $109.99
36172-P08-015 014 GASKET, SOLENOID BASE - 1 $6.58 $4.85
37250-PR3-003 015 SWITCH ASSY., VALVE TIMING OILPRESSURE - 1 $58.57 $43.22
90002-PJ7-010 016 BOLT, FLANGE (6X45) - 6 $2.73 $2.01
90002-PR3-000 017 BOLT, FLANGE (6X55) - 2 $2.58 $1.90
90004-PE2-005 018 BOLT, SEALING (10MM) - 1 $2.80 $2.06
90006-PG6-003 019 BOLT-WASHER (11X155) - 10 $8.45 $6.23
90014-PR3-000 020 BOLT A, HEAD COVER - 4 $4.95 $3.65
90026-PE0-000 021 BOLT, STUD (8X37) - 2 $2.98 $2.20
90401-PE2-003 022 WASHER, SEALING (10MM) - 1 $1.93 $1.42
90701-679-000 023 PIN, DOWEL (8X10) - 1 $2.22 $1.63
91302-GE0-000 024 O-RING (8.8X1.9) - 1 $1.85 $1.36
91319-PR3-003 025 O-RING (13X1.5) (ARAI) - 1 $2.05 $1.51
92900-08025-1B 026 BOLT, STUD (8X25) - 6 $0.87 $0.63
93500-05008-0H 027 SCREW, PAN (5X8) - 1 $0.40 $0.29
94301-10120 028 PIN, DOWEL (10X12) - 18 $1.97 $1.45
94301-14200 029 PIN A, DOWEL (14X20) - 2 $1.12 $0.82
95701-06018-08 030 BOLT, FLANGE (6X18) - 3 $0.62 $0.45
95701-06030-08 031 BOLT, FLANGE (6X30) - 3 $0.90 $0.66
95701-08050-00 032 BOLT, FLANGE (8X50) - 16 $1.00 $0.73
actually here ya go
not for sure if its the same with a gsr, but there is a small harness on the pass. side under the dash, w/ 2 prongs, take a paper clip, push both ends, and it will reset. this was for my ls, but i couldnt figure out why the light came on, but apparently it comes on every 3k, whether i changed the oil or not,lol.
