main relay is going off and ecu light stays on??????????
Old 01-30-2009, 12:12 AM
90lscrx's Avatar
90lscrx is a name known to all90lscrx is a name known to all90lscrx is a name known to all90lscrx is a name known to all90lscrx is a name known to all90lscrx is a name known to all
Default Re: main relay is going off and ecu light stays on??????????
What ecu is in your car.
90lscrx is offline
Old 01-30-2009, 06:15 AM
youngj29's Avatar
youngj29 has disabled reputation
b16
youngj29 is offline
Old 01-30-2009, 06:28 AM
ohh yea
integrab17's Avatar
integrab17 has disabled reputation
so does it even crank now ..wat happens when u try to turn it on
integrab17 is offline
Old 01-30-2009, 11:21 PM
youngj29's Avatar
no fuel
youngj29 is offline
Old 02-01-2009, 10:18 AM
ChokolAwt's Avatar
ChokolAwt ChokolAwt ChokolAwt ChokolAwt ChokolAwt ChokolAwt
im assuming your car is OBD0... so is the little red led on solid when you turn the key?
the only reasons for that are bad grounds, or blown fuses... did you actually remove the fuse? have you checked it with a test light?
you could also check your main relay and fuel pump voltage...
ChokolAwt is offline
Old 02-01-2009, 10:50 AM
So you're saying the CEL is on, but the fuse could be blown? So where is the power to light the red LED coming from? Think about that for a second.
Old 02-01-2009, 01:04 PM
youngj29's Avatar
i did it all even put in new fuel pump
youngj29 is offline
Visualimpact757
Want to Buy / Trade ARCHIVE
07-27-2008 08:36 PM
integrarj
03-27-2006 07:18 AM
Quick Reply: main relay is going off and ecu light stays on??????????
