ls/vtec turbo or gsr turbo?
Old Aug 19, 2006 | 07:37 AM
  #51
LSVTECEG757's Avatar
<3 2JZ
LSVTECEG757 has disabled reputation
Default Re: ls/vtec turbo or gsr turbo?
well i have done a ls/vtec setup and so far haven't had any problem with it. The crank is knife edged, forged internals, sleeved, and built b16 head. it's built for boost but i haven't had the money to boost it. But it still pulls harder than my friends gsr crx.
Old Aug 20, 2006 | 09:43 AM
  #52
crazyb's Avatar
crazyb is an unknown quantity at this point
thnx man tryin to sell it lol ill boost it for ya! ha ha
Old Aug 20, 2006 | 01:58 PM
  #53
Yell88CRXsi's Avatar
Team Ultraspeed
A sleeved LS & CRV block, will have about the same structural strenght as a GSR, ITR or even a B16 block for that matter. The only advantage that the LS/CRV blocks would have is the ever so slightly higher 212mm deck height versus the 211.84mm of the GSR/ITR's. This really doesn't matter for 99.9% of the people who builds motors and do not play with custom rod and pistons pin heights. That, and the fact that you can get LS/CRV blocks cheaper.
Now the advantage of GSR/ITR blocks would be of course the main girdle. As for the oil squirters, some people see them as a disadvantage because of the oil pressure that they waste. A set of coated forged pistons will compensate for the lack of oil squirters. If you choose to run squirters just make sure to run a 94+ vtec oil pump as they have a higher pressure output to compensate for the oil squirters.
I wouldn't worry about knife edging the crank. As Scott said, Honda cranks do not sit in the oil as some others do. Knife edging requires the removal of material from the counterweights. Doing so...you will lose rotational mass...hense quicker spool up, but at the cost of torque. On a FI motor I wouldn't worry about this as once in boost...you'll find that the motor will spool up just fine
Other than this...the 87.2mm GSR/ITR, and 89mm LS/CRV cranks are all about the same when it comes to torque. Your numbers may slightly differ, but not by much.
The real different between the cranks is displacement. The more you increase stroke, the more displacement you make. The more displacement you can make, the more power. The problem is with every action...there is a reaction. In this case, the more you increase stroke, the more you increase piston speed. Increase piston speed compounded with higher RPM's can cause more interial forces which if not addressed, can and will in most cases cause rod failure. Other issuses like less TDC dwell time, decrease cylinder filling, and of course, cylinder side loading are all increased when increasing stroke. NOW BEFORE YOU START, NOWHERE DID I SAY THAT INCREASING STROKE IS BAD!!!
It's just one tool of many when trying to make power.
And finally, which head is better? It really depends on who you are and what you are doing to do to the head. As said earilier, the PR3 heads tends to slightly have more options available than the P72. This does not mean that it is better. I prefer virgin (never ported) PR3 heads. But I'm sure there's more than one person on here who will tell you different.
As far as heads go...I will say that with most engine...the ablity to flow air is the most important thing. There's a saying that "all the power is in the head" and it's true! So with, I would build the head and have it port by someone who has a good rep for porting...but more important...has a flow bench!
That's my rambling for the day.
Old Aug 20, 2006 | 02:08 PM
  #54
crazyb's Avatar
so your saying i am wasting my time on a sleeved block ...so a gsr cylinder walls will hold 25 psi?
Old Aug 20, 2006 | 02:10 PM
  #55
Team Ultraspeed
No no! Get it sleeved by all means!!! Aftermarket sleeves will always be stronger than OEM cylinder walls
Old Aug 20, 2006 | 02:29 PM
  #56
crazyb's Avatar
oh ok i was wondering because someone else was trying o tell me that i was like i can t see a stock cylinder holding that pressure but.... u know anyone with a sleeved block for a decent price?
Old Aug 20, 2006 | 02:32 PM
  #57
JDMS1eeper's Avatar
JDMS1eeper has disabled reputation
You should go LSvtec turbo. At that power just do Rods/ PIstons and Springs and Retainors.
You shouldnt set your self up for problems down the road by building a setup for 10 billion RPMs when you could just keep it cheaper / simpler for yourself by keeping it basic.
My setup made 366 on 10psi, Stock B16 topend. 84mm Sleeved/built LS b18b bottomend. I'll post the dyno too
Old Aug 20, 2006 | 02:37 PM
  #58
crazyb's Avatar
thats true man but i am a hog if i do something its to the extreme i mean why go a lil fast when i can whip ass
Old Aug 20, 2006 | 02:42 PM
  #59
Team Ultraspeed
Although I do not disagree with you, What is "basic" for you and I may not be for someone else.
Old Aug 20, 2006 | 09:31 PM
  #60
Boost Happy's Avatar
www.TeamDOHC.org
Boost Happy Boost Happy Boost Happy Boost Happy Boost Happy Boost Happy Boost Happy Boost Happy Boost Happy Boost Happy Boost Happy
500+WHP on stock sleeves is more than achievable. Provided, that you do not encounter detonation. The first hard slam you get, your sleeves are at extreme risk of damage.
