ls vtec oil problems
Old Nov 22, 2007 | 04:23 PM
DORKO's Avatar
Bearded.
Default Re: ls vtec oil problems
is this the motor that was sitting on your floor?
did you put this motor in the crx in front of the garage.?
if so i hope you didnt fuck something up
Old Nov 22, 2007 | 09:19 PM
Tim-Tim's Avatar
Tim-Tim can only hope to improve
yea thats the 1. im gonna pull the oil pump off and try another one. ive double and triple checked everything. ill see what that does. even though its new it could still be a bad egg.
Old Nov 23, 2007 | 06:38 AM
wisepanda's Avatar
got some fake hp
wisepanda has a reputation beyond reputewisepanda has a reputation beyond reputewisepanda has a reputation beyond reputewisepanda has a reputation beyond reputewisepanda has a reputation beyond reputewisepanda has a reputation beyond reputewisepanda has a reputation beyond reputewisepanda has a reputation beyond reputewisepanda has a reputation beyond reputewisepanda has a reputation beyond reputewisepanda has a reputation beyond repute
Originally Posted by Grease Monkey
on the block where it meets the head towards the back there is a metal insert.. it's between cyl 2&3 on the intake side..
+1 THIS IS VERY IMPORTANT
what kind of oil filter are you running? the reason i ask is becuase some hold such a big volume of oil it will cause low oil pressure, i would never run anything other than a honda filter! and what is the size of your feed line goin to the head? and how low is low? when you say oil pressure is low, what are you using to measure this. also if you are running a thick oil(anything thicker than 10W-30) i have seen this influence oil pressure. does the motor cross-over?
how do you know you just dont need a tune and a valve adjustment?
Old Nov 23, 2007 | 07:24 AM
CavemanRacing's Avatar
www.CM-R.net
CavemanRacing CavemanRacing CavemanRacing CavemanRacing CavemanRacing CavemanRacing CavemanRacing CavemanRacing CavemanRacing
Originally Posted by donhohos
i just drove my car for the first time tonight after building my ls vtec motor. 99 bottom end with 00 si head. EVERYTHING is new from ..............
There's your problem, right there.
Old Nov 23, 2007 | 07:05 PM
Tim-Tim's Avatar
your just jelous.....if it aint a d series it aint right
Old Nov 23, 2007 | 07:12 PM
Tim-Tim's Avatar
i was using a fram oil filter i usually fun k&n filters but auto zone was out of them and being the holidays it wasnt open. so i bought another fram filter which was better than the first. the thing is that the oil pressure fluxuates (sp?) on cold start ups it runs all the way to near 100 psi after it warms up it rests at 25 and below. also i am using a mechanical oil pressure gauge tied into the back of the block. i am not sure of the diamater of the oil feed line to the head but its pretty big. bigger than a -6 an hose like golden eagles kit. i am running 5w30 valvoline motor oil and the motor cross over? i am assuming you are talking about vtec. i have not yet reved that high ive only got 3 miles on the motor so far. i may need a tune i plan on getting one but the valves were adjusted when the top end was assembled.
Old Nov 23, 2007 | 09:45 PM
Jarrod's Avatar
braap braap
Whats oil pressure at when VTEC crosses over?
My b16 was at like 22psi at idle and it was low 90s when it first started up.
Old Nov 24, 2007 | 05:11 AM
www.CM-R.net
bologna
ps - i told josh to ask you how to do this nonsense on that integra, he wants to do it
Old Nov 24, 2007 | 08:35 AM
wisepanda's Avatar
got some fake hp
like jarrod said at idle you should be anywhere from 20-30 psi. and cold start your pressure will be pretty high because of the properties of the oil. My ls/vtec idled at 25psi, and when it crossed over(VTEC) it was at 75/80 psi. From the sound of it i would say break the motor in unless the top end just sounds so horrible. I would recomend taking the valve cover back off and making sure none of the rocker arm nuts are loose if its making that much noise. BUt break the motor in and go get it tuned(i can never stress that enough). I mean the setup sounds pretty stock from your explanation of the motor its self, so it should run good enough to get it broke in and then you can go from there.
Old Nov 24, 2007 | 10:29 AM
Tim-Tim's Avatar
i am repacing the oil pump now. taking a smoke break. the pressure would be at 25 or below but usually rested below 10 psi. its only got 3 miles on it now i did have a ls in the car before and oil pressure was usuall around 30 to 40 so i am assuming thats normal. so thats what i want. also i did pull the valve cover off and the lifters do need to be tweaked somemore. ill update when i am finished.
