Low RPM cut out
Low RPM cut out
So, my car occasionally cuts out at low RPMs and after a few seconds of hesitation and more throttle will come back to life. Was told originally that it was my spark plugs, so I got new spark plugs(gaped to .044), wires, distributor cap and rotor, still the same problem. I have researched it countless times and still have not found an solid answer. So before I spend a bunch more money on parts I dont really need, just want to get an answer or a few suggestions. Oh yeah, the car is a 2000 honda civic si, with a JDM b18c-R swap if that helps. Thanks in advanced. Will try to answer as many questions as I can to help you guys out with figuring out the problem, but my no means am I a Wiz on this.
In the honda game...
Re: Low RPM cut out
damn man my car has been doing this to and been searching for sometime now and still can find out whats wrong...i replaced my fuel filter, and iac valve no luck
Re: Low RPM cut out
Yeah it sucks really makes my car sound shitty. So I don't even drive it. Good luck fixing it. I will let you know what I did to fix it soon, hopefully.
