Local Engine Swap SR20DET
Maybe you are referring to droping a DET into a 1.6 car. Dropping it into a 2.0 car is pretty easy. You dont touch the dash or anyting like that. You swap over the US market water temp sender. Most of the other stuff plugs right in. Dending on year you might need to re-wire the distributor. You can use the stock MAF or upgrade to a Maxima maf that is a direct bolt on. I was speaking about the sr20de to sr20det swap being easy. Never worked on the 1.6 before for swaping in a 2.0. That is not nearly as easy.
I was assuming he was talking about a S chassis ... for a B chassis you may be correct.
Even though some of the FWD SR have blacktops I've only heard them being referred as Bluebird and GTi-R. That's why I assumed S chassis.
Originally posted by Chezkers
blacktop sr20det with intercooler complete?
__________________
Got a 1995-1996 240SX? Want a new front bumper?
Check this out. Posting on drag first to try and avoid shipping it.
