jdm steering wheel install -- help
Old Jan 11, 2003 | 07:34 PM
slwhnda's Avatar
slwhnda is an unknown quantity at this point
Default jdm steering wheel install -- help
92 Civic CX, JDM wheel w/ no airbag.
ok, i got my stock wheel and airbag off , but i have a question..
the cable reel coming out by the shaft with two yellow plugs on it.. one for the airbag and one for the horn im guessing? what do i do with these? the new wheel wont fit on with these plugs in the way..
please advise! my car is steering wheel-less until i get a reply
Old Jan 12, 2003 | 04:34 AM
S dot Camp's Avatar
Asshole Supreme
Take the whole SRS wiring harness out of the car. Or just move it to another location. Just remember that you weill have an SRS light on if you don't remove the whole SRS system.
Old Jan 12, 2003 | 07:50 AM
eng's Avatar
eng
Administrator
eng eng eng eng eng eng eng eng eng eng eng
Default Re: jdm steering wheel install -- help
Yellow "things" (connectors, wires, wire wrap, etc) in your car should only be for SRS. So I'm not really sure why you have 2 yellow plugs. Mine was a yellow and black connector.
Do you have a Haynes or a FSM for you car? That'd be a big help.
Old Jan 13, 2003 | 12:26 PM
slwhnda's Avatar
the second flat yellow connector was for cruise control. but i just removed the entire little cable reel, but my srs light is still on. i guess i need to short it somewhere, or pull the cluster and unplug it from there. thanks
Old Jan 13, 2003 | 01:13 PM
lightningd's Avatar
co driver
lightningd lightningd lightningd lightningd lightningd lightningd lightningd lightningd lightningd lightningd lightningd
be careful, you might set off the air bag. get a haynes manual, it tells you how to disable it.
Old Jan 13, 2003 | 02:19 PM
eng's Avatar
eng
Administrator
Almost all of the hubs I've seen for SRS cars come with a connector that mates to the airbag one. Inside the other end of it is a fuse.
I'm guessing shorting it will work, but what happens when the car tries to set off the airbag?
Then again, if you've done something to set off the airbag I'm not to sure you really care about the electronics of the SRS.
AdubsGSR
Aug 22, 2008 08:47 AM
phantasticphan
Apr 25, 2007 03:48 PM
PRO-Habit
Feb 9, 2006 12:05 PM
IRR0MPIBLE
Sep 8, 2005 02:28 AM
