issues, possibly tuning problem with high compression b20 vtec in eg coupe
Old 11-15-2008, 12:34 PM
dustyb20's Avatar
dustyb20 dustyb20 dustyb20 dustyb20 dustyb20 dustyb20 dustyb20 dustyb20 dustyb20 dustyb20 dustyb20
Default issues, possibly tuning problem with high compression b20 vtec in eg coupe
Ok here is my problem, yesterday i went to pay a few bills... well i have a tendency with my setup (which is mentioned below) to sit for a moment or two and load up on fuel. Needless to say, i ended up sitting at a traffic light for about 7-10 minutes with an already warm car, took off and car was hesitant, or maybe i should say jumpy, as it acts when it tends to load up. I proceeded to clear it out a bit taching the car out 2nd thru 4th to about 6.5k rpm's, CAR DROVE FINE, hence my reasoning for thinking a fuel load up... well i went in paid my bill, come out and can't start the car. Fuel pump engages, everything comes on fine, whirls over and then BOOM followed by a white smoke coming from my INTAKE! backfire, sounds like it's coming mid exhaust... well i let the car sit a few hours had a buddy come pick me up. Later on i went back, removed plugs (which were BLACK black) manually turned crank to check timing, which is good, getting spark (which is evident), fuel pressure regulator functioning properly... so i decide to retard the timing a bit thru dizzy (thinking it may be bad fuel), to my astonishment, cranks up drive it home.
Now this morning, thinking (from personal experience) possibly a distributor problem, since no clunking sounds or anything of the sort coming from the bottom end, removed valve cover and all valves retainers and such seem fine, placed on new dizzy (used same rotor button and cap though), new plugs (NGK iridium 4's), and REDID the timing (just because it looked about a half notch off (figured that might've been why when i retarded the timing it started no problem, possibly off a tooth or 2)... go to start it up again and same thing happens!!!!
WHAT CAN I DO!?!?!?!
now for my setup, this is all in a 93 civic coupe...
B20b bottom end
R-spec 84mm ITR replica pistons
stock rods and crank
B16a1 HEAD
stock valvetrain
aftermarket cam, stage 1 most likely but resemble GSR cam in markings and lobe
AEM adjustable cam gears (tru-time)
310cc precision injectors
warlboro 255lph fuel pump
ebay fuel pressure regulator
AEM fuel rail
stock b16 intake manifol w/ intake (no filter)
type r 4-1 header replica with 3" coupler connected to straight pipe 2.5" exhaust with 40 series flowmaster muffler (no cat, no resinator)
NGK iridium 4 plugs
NGK 10.5mm wires
95 GSR dizzy
this setup was "street-tuned" on chrome, by a friend... has ran GREAT for last 6 months on 60 lbs thru the fuel pressure regulator... it hasn't seen a dyno and by no means is "tuned"... but is and has been at an acceptable area, if anything running rich with no problems what so ever until the past 2 days of constant rain, moist/cold weather
now with all this being said, new dizzy, plugs, and timing being adjusted, can ANYONE give me an idea of where i should try next, as well as can anyone tell me if the change in moisture of the air will cause this to happen... i know that atmospheric and barometric conditions can effect the preformance of an engine, but this badly? and the compression of my motor is right high at the moment. Maybe a fuel system flush, drop the gas tank, clean it out nicely, run some 93 octane with fuel cleaner and pray for the best? Maybe a problem within the ECU, since no CEL's? Vacuum leak possibility? Tuning is a worry of mine, as i do have hondata s200, it's just that now with this current problem, it won't look as if that'll happen within the next week or so as planned (i'm surely not towing my non running car to a dyno, if that's not the issue). ANY HELP with this problem would be much appreciated
thanks in advance, and sorry for such a long description, just figured it might help
Shawn
dustyb20 is offline
Old 11-16-2008, 04:25 AM
dustyb20's Avatar
Default Re: issues, possibly tuning problem with high compression b20 vtec in eg coupe
looking into possibilities today of injector fouling up, vacuum leak, and clogged exhaust... replaced dizzy, put car in time, valves and all look great, bottom end looks great, new plugs and everything getting spark, fuel filter is fine (fpr getting consistent 60lbs.), still no CEL's... fun day ahead
dustyb20 is offline
Old 11-16-2008, 02:27 PM
Moist, cold air is much denser than dry, warm air. It's probably just running too rich because of the air density is higher and the tuning is probably really far off. Why are you running 60 psi fuel pressure? You don't have any need for a FPR, fuel rail, or fuel pump on your setup, and 60 psi fuel pressure isn't giving you any gains at all, especially if you haven't actually been tuned by a pro on a dyno. Knock that down to roughly stock fuel pressure for a start, like 45 psi or something. There just isn't any reason for pressure that high on a non-turbo setup, especially if you have an actual way to tune the A/F ratio (which you do).
It sounds like everything is working properly and you probably just have a really bad tune. You may have a sensor going bad, but the fact that it started doing this when the weather changed leads me to believe that now you're operating in an area of the tune that you haven't been in before. You may have fouled your O2 sensor, but that shouldn't cause problems with cold starts.
So you really need to get tuned, and I wouldn't chase your tail too much until then. You can swap out all the parts that you want and you'll still run like shit without proper tuning.
Old 11-16-2008, 02:48 PM
MAGICAL FRIENDSHIP
streetlamp's Avatar
streetlamp streetlamp streetlamp streetlamp streetlamp streetlamp streetlamp streetlamp streetlamp streetlamp streetlamp
I've never heard of a car "loading up on fuel"?
streetlamp is offline
Old 11-16-2008, 04:01 PM
dustyb20's Avatar
well i noticed today while going over vacuum lines that timing had jumped a tooth, put everything to TDC, jumped tooth again, bought new timing belt (evidently it stretched), reset everything to tdc, DROPPED the fuel back a bit to 46lbs cranked her up and running fine now... matter of fact MUCH peppier eventhough she ran beautifully before, but i did honestly expect that. this "tune" or map that was wrote for my setup is only a temporary chip and does have it's spots where it shows inconsistancies throughout the rpm's (very slight noticeable hesitation between 3.4k-4.1k rpms 3rd gear) . i do know that i need the car tuned and i'm currently on a wait list to have it done by someone that i consider (as well as many others) a very competent individual, it's just i have a lil over a month before it is my turn FORTUNATELY, i only drive .42 miles a day to and from work, but i think i'll end up parking it until i can take her to the dyno, cranking her up letting it warm up and cycle oil/fluids and just take my beater to work
dustyb20 is offline
Vtec kid
Engine / Exhaust / Drivetrain
03-17-2009 04:19 PM
watisjdm
Want to Buy / Trade ARCHIVE
12-10-2008 05:25 AM
dustyb20
07-21-2008 09:57 AM
MGXhatch
02-17-2008 03:27 PM
-JB-
10-15-2007 05:20 AM
Quick Reply: issues, possibly tuning problem with high compression b20 vtec in eg coupe
