Huge problem...any advice will help
Old Sep 20, 2004 | 02:15 PM
94_CRVtec's Avatar
94_CRVtec has disabled reputation
Default Re: Huge problem...any advice will help
I checked the timing and valve lash and all that shit, its all right on, the valve lash for the came is same as the stock valve lash...im all out of ideas, dose anyone else have any other thoughts
Old Sep 20, 2004 | 04:22 PM
sk8rmike's Avatar
Bitches get Stitches
i would have someone else set your timing just to be sure you arent doing it incorrectly. also, running a b20/vtec im assuming you are using a chipped ecu, right? most chipped ecu's are made to not look for certain things which might help explain the lack of any CEL's...which cams are you running?
Old Sep 20, 2004 | 05:39 PM
94_CRVtec's Avatar
comp cams
Old Sep 21, 2004 | 05:32 AM
hatch77's Avatar
Cruising @ 8000ft
hatch77 is an unknown quantity at this point
Originally Posted by 94_CRVtec
comp cams
heh heh....sad times
Old Sep 21, 2004 | 04:07 PM
spooledex's Avatar
spooledex spooledex spooledex spooledex spooledex spooledex spooledex spooledex spooledex spooledex spooledex
ever do a compression check on it. Just wondering.
Old Sep 23, 2004 | 12:41 PM
94_CRVtec's Avatar
did compression test, everything is fine
Fried_Chicken
Sep 3, 2008 04:40 AM
dsmpwr25
Apr 5, 2008 07:45 PM
TheMx3
Apr 5, 2008 11:30 AM
O Rly?
Dec 3, 2007 10:40 AM
dorydorydriftin
Mar 26, 2007 11:48 AM
