Huge problem(ka24de) need semi-experts
other day driving home i noticed my temp was running high,, no big deal at first,, later that day after i had put in more anti-freeze i heard a strange knocking noise comming out of the engine,, higher the rpm faster the tapping/knocking went.. Car is running ok,, in that i mean you can drive it for hours . Had a friend suggested cracked/broken rod and when i went through and pulled spark plug wires 1 then 2 and etc... The knocking stopped on the 4th plug.. So does this mean i broke/cracked a rod on the 4th cylinder ? and if so what are some alteratives to just dropping a new engine in ?
Whats up I got a crx and I had a sim. problem. I had a built ZC DOHC built with pistons, rings , rods, headers, port & polished......ect anyways I was driving also same thing to make a long story short one of my the cam shaft on my exhaust side snaped in half due to starvation of oil....(note) just had my oil changed 2 days before that happen my oil pump went out and fucked my whole head up so I swaped motors same price give or take in your case ether up grade and rebuild everthing or swap out engins....sorry for your luck
I don't know alot about your motor but couldn't you drain the oil/drop the oil pan to get a better look and see if there's any noticeable damage/metal shavings in the oil pan.
If you know for sure it's rod knock it's really just a matter of time before it goes. Did you ever plan on turbo-charging the KA or eventually doing an SR swap? If so, looks like now is as good a time as any to build the motor or swap it. If you planned on just keeping things relatively stock you could probably source a KA bottom end(or even complete motor) from someone who swapped their 240. Best of luck either way.
well ya I have talked about rebuilding and turoboing the Ka, but ima have to look at the finaces haha. And na no noticable damage to the spark plug
OR DO A leak down test on all cylinders.....might be a busted head gasket...common nissan problem...i've owned two and both times...headgasket was the problem.....now they are sold and swaps were done.....
ya oil is fine,, and i checked the oil lvl it was fine,, also checked oil for water, and gas in it no signs. Umm drove the car today car redlines a 7k and when i gave it gas i heard the engine redline at 4k so wtf?? when you pull the spark plugs individualy the car runs noticably worse, meaning that all 4 cylinders are fireing.. Drove the car today for about an hour , seems like when i change outa 2nd and 4th gear the knock is worse. So me and my dad were thinking its something rotating like a flywheel >> honeslty i have no clue whats wrong, does millenium autosports or could they run a diagnostic check ? or does someone who lives near the western branch area lend me a hand maybe , thanks to all help
