How does Nitrous work?
Old Nov 12, 2002 | 04:31 PM
JdM-BRiD's Avatar
MMMMMMMUGEN!
JdM-BRiD is an unknown quantity at this point
Default How does Nitrous work?
Can someone please explain with as much detail as possible on how nitrous works and the difference of the 3 setups, dry, wet, direct port.
Old Nov 12, 2002 | 05:02 PM
trip's Avatar
///m thrizzle
trip has disabled reputation
dry is just nitrous injected
wet is nitrous and fuel injected
direct port is nitrous and fuel into each cylinder indivually
fogger is a nozzle in the intake hose
n20 breaks down and the oxygen goes into the combustion chanber which allows more fuel to be burned with the extra oxygen and therefore making more horsepower
the N chills the intake charge greatly making the air colder and cold air is more dense than hot air therefore carrying more oxygen and again allowing for more fuel to be burning in the combustion chamber
this is it more or less and someone correct me if i am wrong
Old Nov 12, 2002 | 05:39 PM
growley's Avatar
Pre-"Crash" Member
growley growley growley growley growley growley growley growley
n2o splits at approximately 567 deg F
Old Nov 12, 2002 | 07:40 PM
zexpwrd4door's Avatar
R E U P Gang
zexpwrd4door zexpwrd4door zexpwrd4door zexpwrd4door zexpwrd4door zexpwrd4door zexpwrd4door zexpwrd4door zexpwrd4door
N2O is a great thing.....ummmm spray?
Old Nov 14, 2002 | 10:19 AM
Vengance's Avatar
tired of walking
Vengance has disabled reputation
you better be sure that you install a correct set for your car or else damage can be done. i've had friends blow engines.
Old Nov 14, 2002 | 11:21 AM
s2k7's Avatar
s2k7 has disabled reputation
shut up mom
Old Nov 14, 2002 | 12:17 PM
DoC-JoneS's Avatar
Doin' (today) stuff
DoC-JoneS DoC-JoneS DoC-JoneS DoC-JoneS
anyone know about a universal fogger system for a V6? i'm looking at geting one someday, just like a 60-75 shot. I can't seem to find many universal systems... NO ONE makes a SHO nitrous kit...
Old Nov 14, 2002 | 02:46 PM
Heat's Avatar
HAM
Heat Heat Heat Heat Heat Heat Heat Heat Heat Heat Heat
I'll add a few points:
The reason for the n2o (not N twenty and not NO2 like a lot of people like to type) is that the nitrogen bonded with the oxygen makes the molecule more stable. The oxygen is the actual fuel. More oxygen = more fuel = more bang = more go fast.
This is why nitrous is "forced induction"
If it wasn't for the nitrogen bonded with it, the oxygen would burn up at a lower temperature and cause pre detonation much in the same way low octane does in a high compression/turbo automobile.
This is one of the reasons I do not like nitrous oxide as a mod. You're taking more fuel and dumping it right in from a seperate tank instead of a power adder like sc or turbo that is actually part of the working engine.
Old Nov 14, 2002 | 04:10 PM
trip's Avatar
///m thrizzle
omg... omg... im so sorry i meant n2o so now you know what im talking about.
JERK!!!!!!!!!!
Old Nov 14, 2002 | 04:33 PM
Blasphemous's Avatar
Former 757'er
Blasphemous Blasphemous Blasphemous Blasphemous Blasphemous Blasphemous Blasphemous Blasphemous Blasphemous
Look at the NOS pro-import fogger systems. They're not exactly universal systems because it says it's for a 4cyl, but you can put it in anything I'd imagine.
