Help with overheating
Old Jan 4, 2006 | 09:04 AM
  #21
Moriar's Avatar
Moriar has disabled reputation
Default Re: Help with overheating
Originally Posted by mnchvgs79
Honestly, if it doesnt boil over or even get into the red, I really wouldnt worry about it, but you could try buying a new thermostat, they are only like $10.
Also, make sure you are running a 50/50 to 25/75 (green) coolant/water mix, don't use that orange shit.
It shouldnt even be sitting at that range, it should be below 190.. this is my little brothers car and cant afford to have his car to blow the motor.. im gonna check the sending unit in about 20 minutes when a bay opens up.
Old Jan 4, 2006 | 09:12 AM
  #22
EEK's Avatar
EEK
卐 Walnuts
well also if your HG is blown, at idle it would be struggling (100/200rpm range) you would hear the compression leaking out
Old Jan 4, 2006 | 09:52 AM
  #23
Cobra4B's Avatar
Fanboi
Adam that orange "shit" is Dexcool developed by GM and spec'd to last 5 years of 150k. While I'd never let it go that long, it is a superior coolant. I drain/re-fill mine annually.
Old Jan 4, 2006 | 09:57 AM
  #24
mnchvgs79's Avatar
Custom User Title
mnchvgs79 is an unknown quantity at this point
You have a GM, maybe it's good for your car, but for the rest of the world, that ORANGE SHIT is BAD NEWS, do some research.
Old Jan 4, 2006 | 10:01 AM
  #25
mnchvgs79's Avatar
Custom User Title
One example.
http://www.wcpo.com/wcpo/localshows/.../20299ce7.html
Old Jan 4, 2006 | 10:31 AM
  #26
Cobra4B's Avatar
Fanboi
I have heard that if subjected to air in the system it can corrode/gum up faster, but if properly maintained it's great.
FWIW you cannot mix the two types of coolants.
Old Jan 4, 2006 | 10:38 AM
  #27
mnchvgs79's Avatar
Custom User Title
When I first put the 302 in my truck, I thought I would be fancy and run that dexcool shit, my truck kept boiling over and there was nastiness floating around in my cooling system, thats when I did some research and posted on a few forums and found out that dexcool is bad.
On a side note, I used Engine Ice in my motorcycle and I couldnt keep it below 130 degrees, then I switched back to regular ole green coolant and water and everything resumed normal operation.
Getting to the point, green coolant and water > all.
  #28
Moriar's Avatar
I use texaco green coolant, then pour half of it into an empty one and mix it that way.
Old Jan 4, 2006 | 10:39 AM
  #29
mnchvgs79's Avatar
Custom User Title
Perfect.
Old Jan 5, 2006 | 09:22 AM
  #30
Moriar's Avatar
Took the thermostat out, and she is runnin like a champ now. hmm.. i guess no Advanced Autopart T-stats for me anymore.
