Help need info for acura build
Hello every one. I am working on a project in my spare time. I put a h22a4 in a Acura Cl and am to the point where I have done a good bit of a wire tuck and shave but am at a loss for info. I have deleted and gotten rid of quite a few things i.e. egr components, charcoal can, cruise control, ac pump and lines, power steering, and maybe a few other things. I am wanting to relocate my wiring harness that you see on the left hand side of the picture. I removed quite a bit of my dash and console and was disapointed to see a lot of what I assume is climate control stuff. Stuff that makes it much harder to do what I want with wires and relocate fuse boxes that are now in a inconvenient place ( under the carpet by the ecu pas side) Any info that you can provide will be great thank you![ATTACH=CONFIG]134430[/ATTACH]
Re: Help need info for acura build
the question was sort of broad and not posed in a question form. I suppose i was asking if someone could give me a step by step thread as I have looked and could not find one. or info on the subject in some other form.
If I were to pose more specific questions it would be what porthions of the climate control boxes under the dash i could remove to make room as i have taken the ac components from the engine bay?
another would be what i would need for a abs delete and where i can get it?
I have read it is a prop valve but out of what make and model/ year of vehicle?
In truth I would like to leave the abs in but am not sure how or where to relocate the big module on the left side of my engine bay because it is a nice safety feature.
