help code 8: tdc sensor
Old Aug 9, 2009 | 01:45 PM
jdmasfuk's Avatar
jdmasfuk has disabled reputation
Default help code 8: tdc sensor
I have a 00 si and im throwing code 8.. How do i fix this the sensor its in the dizzy do i have to replace the whole dist.?? also is this the reason i have no vtec? thanks
Old Aug 9, 2009 | 02:08 PM
Default Re: help code 8: tdc sensor
Yes. And yes.
That's one of the major engine position sensors, and that will keep the engine from running properly, so VTEC won't be green lighted to engage. Usually the whole distributor has to be replaced, yes, but that assumes that the problem isn't a wiring issue. Borrow a used distributor from a friend before running out and buying a new one.
Tim-Tim
Sep 2, 2008 05:52 PM
b18c1EJcivic
Sep 30, 2005 12:02 PM
zipties
May 10, 2004 07:07 AM
SCOOBY STEVE
Feb 2, 2004 07:12 PM
see are x
Feb 14, 2003 07:44 AM
