help on changing thermastat for and ls
Old Dec 7, 2005 | 11:08 AM
1qikcoupe's Avatar
1qikcoupe has disabled reputation
Default help on changing thermastat for and ls
close thread
Old Dec 7, 2005 | 11:20 AM
chirp the 1-2's Avatar
Daddy status
chirp the 1-2 is an unknown quantity at this point
Default Re: help on changing thermastat for and ls
The thermostat gasket should have a split all the way around it which is where the rim of the thermostat slides in it. Should be a recess in the rubber where the little metal thing (whatever its called) should be in. Then it should fit perfect.
Old Dec 7, 2005 | 01:50 PM
Gustav's Avatar
Gustav is infamous around these partsGustav is infamous around these partsGustav is infamous around these partsGustav is infamous around these partsGustav is infamous around these partsGustav is infamous around these partsGustav is infamous around these partsGustav is infamous around these partsGustav is infamous around these partsGustav is infamous around these partsGustav is infamous around these parts
Don't forget to open the coolant bleeder valve when filling the radiator with coolant.
Old Dec 7, 2005 | 02:16 PM
King Dingaling's Avatar
Big Dick Playa
King Dingaling King Dingaling King Dingaling King Dingaling King Dingaling King Dingaling King Dingaling King Dingaling King Dingaling King Dingaling King Dingaling
coolant bleeder valve? wtf.
are you talking about the petcock
Old Dec 7, 2005 | 04:16 PM
j4k3's Avatar
holla
im not sure what its called, but i know there is a coolant bleeder valve on some hondas, we were talking about it in class today
Old Dec 7, 2005 | 06:52 PM
SlowLS's Avatar
Sumospeed #O.G.
Once you fill the radiator up with fluid, start the car and let it run with the car off. as the car warms up, the thermostat will open and get the rest of the air out. Keep adding fluid to the radiator and you see it needs it till it remains full.
Old Dec 7, 2005 | 08:37 PM
sk8rmike's Avatar
Bitches get Stitches
on the tstat housing, some honda's came with a bleeder valve there to let air out, some didn't.
Old Dec 8, 2005 | 02:29 AM
Gustav's Avatar
Most pre-98 Honda's have them. Reason being is that the t-stat housing is higher than the radiator fill. So air gets trapped. If it has a bleeder valve, make sure you use it or it is gonna over heat. Fill the radiator, crack open the bleeder and fill the radiator with more coolant until it starts running out of the valve. Close valve and fill radiator the rest of the way. THEN you can start the car.
Old Dec 8, 2005 | 02:50 PM
Big Dick Playa
thats fucking gay.
i always just fill my shit and let it run till it gets hott and the thermostat opens then fill it up once all the air leaves the system then i put the radiator cap on sounds easier to me
Old Dec 8, 2005 | 05:55 PM
sk8rmike's Avatar
whats weird is that some cars have 'em, some dont. never really understood why ALL of them or none did.
LShatch59
Dec 31, 2007 07:47 AM
tiki240
Jul 3, 2007 12:25 PM
Fraud
Apr 19, 2007 12:47 PM
hondazccivic
Sep 30, 2003 12:55 PM
