having problems with my swap
Old Dec 6, 2006 | 12:22 PM
lsvtechatchy's Avatar
lsvtechatchy has disabled reputation
Default having problems with my swap
im trying to get this swap dont one my 96 civic hb im putting a 97 JDM integra typer in it. i bought my motor mounts from avid saying it would fit 96 civic w\ any b series. they all fit but on the tranny there are two studs that stick up the one farest back is to short can i pull this out and just get a longer one or what should i do. then on the driver the mount that mounts to the block the type r one the two studs are too close together to fit the mount so i put the gsr one on an then it was turned to much it wouldnt fit the bracket. if there is anything else that i would need please let me know. can sumone please help me so i can get this beast on the road. thanks john
Old Dec 6, 2006 | 02:04 PM
crxnfx's Avatar
I have a 20 valve...
Default Re: having problems with my swap
I think the mounts from your old engine should fit. 95+ should fit any b-series period. Did you buy special mounts or urethane mounts?
Old Dec 7, 2006 | 04:29 PM
Hatch Man(GsR)'s Avatar
I drive a coupe
Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR) Hatch Man(GsR)
92-95 civics don't need aftermarket mounts. 96 and up needs the drivers side and rear mount from a 99-00 civic Si...
I would send the mounts back, let them know your setup, and tell them that they don't fit...
Old Dec 9, 2006 | 08:26 AM
well ive talked to a few ppl around here and what i need all the mounts fit the car i just have to get the bracket for the driver side mount off of a B16 a or 99 si . but does anyone know if i can take the studs out of the tranny where the mount goes and replace them with longer ones???????
thanks for yalls help i appreciate it
Old Dec 9, 2006 | 11:26 AM
crxnfx's Avatar
as long as its a grade a bolt, sure, use the longer bolts.
Old Dec 12, 2006 | 06:59 AM
zabbai23's Avatar
zabbai23 has disabled reputation
on honda-tech i found a post about avid mounts with the same problem. what happen was the motor ripped out the frame rail and did alot of damage to the car. i have type r in my 99 coupe with hasport mounts. they fit and work great. i wouldnt go with any thing else. just my 2 cents.
civicrider
Mar 8, 2009 05:15 PM
tpage0007
Jul 24, 2008 10:21 PM
Fasian
Nov 1, 2006 11:45 AM
Ej8D16y8-T
Aug 25, 2005 02:06 PM
89 cRiX Si
Jun 13, 2005 04:59 PM
