h23 ecu problems
Old Jan 16, 2007 | 06:32 AM
sohc4life's Avatar
sohc4life has disabled reputation
Default h23 ecu problems
wat ecu do i use for an h23 swap into an eg chasis someone told me i need a custom one any help would be appreciated
Old Jan 16, 2007 | 07:55 AM
KYLE ROSE's Avatar
KYLE ROSE has much to be proud ofKYLE ROSE has much to be proud ofKYLE ROSE has much to be proud ofKYLE ROSE has much to be proud ofKYLE ROSE has much to be proud ofKYLE ROSE has much to be proud ofKYLE ROSE has much to be proud ofKYLE ROSE has much to be proud ofKYLE ROSE has much to be proud ofKYLE ROSE has much to be proud ofKYLE ROSE has much to be proud of
Default Re: h23 ecu problems
stock h23 ecu will run the car.
Old Jan 17, 2007 | 01:08 PM
Stevo8's Avatar
Stevo8 can only hope to improve
He's right but if your H23 is OBd2 then you'll need the conversion harness to convert your OBd1 ECU plugs
Old Jan 17, 2007 | 01:25 PM
RPRacing's Avatar
Huntin Dropa ForLife
RPRacing has disabled reputation
h23s are only obd1.
Old Jan 17, 2007 | 04:25 PM
If you use any ECU other than the stock H23 ECU (or if you want to any tuning with Hondata, etc), you'll need to have the ECU chipped. The best bet for a simple swap is the H23 ECU, and you can get a P28 or something later if you need to get tuned. The H22/H23 ECUs are bastard stepchildren and the programs haven't been hacked like the B and D series ECUs, in case you have a question mark hovering over your head.. That's why you need to use a different ECU to tune with..
Old Feb 3, 2007 | 05:13 PM
cmccarron's Avatar
Big Daddy
cmccarron cmccarron cmccarron cmccarron cmccarron cmccarron cmccarron cmccarron cmccarron cmccarron cmccarron
Cool Re: h23 ecu problems
I have a chipped P28 for $200 or a chipped P05 that has been converted to a P28 for $175. Both have datalogging capabilities and I can add IAB support to either one. Either will work for your application unless you need or want the knock board. I have a tune that will run the car also.
Old Feb 3, 2007 | 05:33 PM
Grease Monkey's Avatar
Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey Grease Monkey
I have an H23 ecu
norfolksfinest
May 8, 2006 07:15 AM
