gsr map sensor code 5 problems
changed everything (rewired, new map sensor, new plug on map, new plug on ecu, i changed from the map sensor on maifold to map sensor on fire wall only thing that changed was from code 3(map sensor) to code 5(also map sensor) its in a 90 teg
Re: gsr map sensor code 5 problems
Have you checked the voltage at the map sensor, and checked continuity of all wires? It doesn't sound like you've done any troubleshooting, just replacing.
