fuel pump???
Old Jul 29, 2006 | 01:07 PM
streetsk8er757's Avatar
streetsk8er757 has disabled reputation
Default fuel pump???
I have a stock 00 SI with a walbro 255lph fuel pump. I am wondering if running the fuel pump with stock injectors and fuel pressure regulator would cause me to run rich? because the excess pressure from the pump pushes the fuel faster and the regulator can only move so much, and might force more fuel in the cylinders?? right or wrong??
Old Jul 29, 2006 | 01:13 PM
MORE IMPATIENT's Avatar
DESTROYS DONUTS !!
Default Re: fuel pump???
correct. that pump will make you run rich, it runs at twice stock pressure. if you dont have the mods to need an upgraded fuel pump, put the stock one back in.
Old Jul 29, 2006 | 01:18 PM
i got the car with the fuel pump in it waht if I was to get an adjustable fuel pressure regulator to allow less pressure build up and use an emanage to level everything out?
Old Jul 29, 2006 | 05:02 PM
DOHC crx VTEC's Avatar
DOHC crx VTEC is an unknown quantity at this point
If this will work...i doubt it...I'll trade you my stock CRX one for it I need a fuel pump to finish up my d-series turbo.
Old Jul 29, 2006 | 05:08 PM
well the car wont be driven to much right now anyways and I am going to need it for my build a budy of mine might have an extra one for cheap!!!
Old Jul 29, 2006 | 05:10 PM
Just let me know! I'm trying to get my crx to the track before summers up.
Old Jul 29, 2006 | 05:49 PM
Jarrod's Avatar
braap braap
Take the fuel pump out, and buy a stock one.
I wouldn't sell it, hold on to it for later mods.
Old Jul 29, 2006 | 08:44 PM
i will if the adj fpr theory doesnt work out anyone with an answer for me??
Old Jul 29, 2006 | 10:20 PM
Jarrod's Avatar
braap braap
Honestly, I don't think you can.
I haven't tried to turn mine down, because I'm turbo'd.
I don't think I could anyways, 30psi is alot to turn down.
I have a B&M unit, and I don't think it'll adjust that much, if you have a different one, you may be able to.
Old Jul 30, 2006 | 03:37 AM
1rude2l's Avatar
it will work but you have to get a actual fuel pressure regulator, not just the 40$ b@m or something like that will do you no good, have to replace the regulator because of the size of the hole i the stock one.......one you need runs around 150-200 depending on who makes it
