fuel pump???
I have a stock 00 SI with a walbro 255lph fuel pump. I am wondering if running the fuel pump with stock injectors and fuel pressure regulator would cause me to run rich? because the excess pressure from the pump pushes the fuel faster and the regulator can only move so much, and might force more fuel in the cylinders?? right or wrong??
Re: fuel pump???
correct. that pump will make you run rich, it runs at twice stock pressure. if you dont have the mods to need an upgraded fuel pump, put the stock one back in.
Re: fuel pump???
i got the car with the fuel pump in it waht if I was to get an adjustable fuel pressure regulator to allow less pressure build up and use an emanage to level everything out?
Re: fuel pump???
If this will work...i doubt it...I'll trade you my stock CRX one for it ;) I need a fuel pump to finish up my d-series turbo. |
Re: fuel pump???
well the car wont be driven to much right now anyways and I am going to need it for my build a budy of mine might have an extra one for cheap!!!
Re: fuel pump???
Re: fuel pump???
Take the fuel pump out, and buy a stock one.
I wouldn't sell it, hold on to it for later mods. |
Re: fuel pump???
i will if the adj fpr theory doesnt work out anyone with an answer for me??
Re: fuel pump???
I haven't tried to turn mine down, because I'm turbo'd. I don't think I could anyways, 30psi is alot to turn down. I have a B&M unit, and I don't think it'll adjust that much, if you have a different one, you may be able to. |
Re: fuel pump???
it will work but you have to get a actual fuel pressure regulator, not just the 40$ b@m or something like that will do you no good, have to replace the regulator because of the size of the hole i the stock one.......one you need runs around 150-200 depending on who makes it
